Intercooler
Grant
  • Member For: 22y 3m 10d
I queried the torque limiting many moons ago - it could be done with a built in G-meter and a base reference "map" whereby the ECU knows what G's are produced at any given rpm with respective boost/torque. So if the G's at say 3000 rpm were greater than base reference, then boost or fuel is controlled to bring torque back down.
  • Replies 67
I would have thought that torque is merely twisting force.
Things that make me go "hmmm...." (sorry, maccas ad on TV... grrr)
Not necessarily every time would the force be put to the ground.
ie, if a G-meter was used, then if, say, I was to "accidentally" break traction in a major way (oops... *grin*) that would mean that the turbo could go unchecked and overboost??? After all, when you're sitting there half sideways leaving nice black twin lines on the road, you ain't pulling too many g's!
However you could easily bust gearboxes, diffs, etc... <_<
Just doesn't make sense to me anyway.
Personally I think it's BS. I want someone to PROVE that it's limiting it, so I can learn how it works! :)
Only way I can think of is that they have the matrix that richdave mentioned, taking information such as fuel, o2, mix, engine revs, etc and some tricky mathematics could be used to control the level of boost to keep things in a specific area of that matrix/curve.
Hm.
Put it this way - if they've found a way which we can dynamically measure the engine's torque output (ie so they can limit it dynamically such as if any mods are done to the car) then they've just done dyno places out of a business... I mean, when you have torque and revs, you can work out power as well... :)
Anyone able to hook something up to the car CAN and listen in for a "torque sensing" broadcast?
C'mon you electronics engineer boffin dudes - break into this sucker so we can go mod-crazy! :)
Guest Turbo-6
  • Guests
Guys what about protection for the intercooler?  It looks a little exposed down there.  I am thinking of fitting a small grill.
The intercooler on my car gets clogged with insects and has been slightly damaged by stone flung at it by another vehicle. I'd hate to think what kind of damage a bird could do. Does anyone know where I can get some protection for the intercooler - perhaps some type of screen/mesh/guard?
  • Member For: 22y 1m 15d
I have brought this up with Brett at MRT Perfomance. I am convinced that the Intercooler is going to get damaged by stones, birds, alligators, rodents cats and other assorted flying bits.
It is low and unprotected. A nice mesh grille will do nicley.....
cheers
Dallas
  • The Noble Leader
  • Administrator
  • Member For: 22y 3m 9d
A bird? :D i doubt it a bird would be flying at that height.. but a grill or something would be a great idea.
  • SLOJAM, Gone but not forgotten
My FIL has a metal works. I'll see if he can whip something up when I get mine...... in about 3 - 4 weeks hopefully (unashamed boasting here :lol: )
Chrome or black powder coat?
  • The Noble Leader
  • Administrator
Black powder coat would look better.. Chrome would look alright too.. I guess you just have to try both and see what it looks like.
Guest esky
  • Guests
is the intercooler on the BA a bar and plate or tube and fin ? . . .. . . .
The cooler in the BA is a Garrett bar and plate.
Having a larger intercooler doesn't mean you have more lag. Lag defines the time it takes for your turbo to reach positive pressure. In the BA about 2000rpm. A friend has a 10second GTR with a T88 turbo. The exhaust turbine wheel is so big it takes about 4000rpm to reach positive pressure. Increasing the size of the intercooler can, but not always, reduce the pressure going into the combustion chamber due to the pressure drop across the intercooler. Well designed intercoolers have little impact. If your really concerned about the flow rate of your intercooler, get it flow bench tested.
A few friends race in super sedans and GTP, and I’ve never known them to get their coolers tested. A cheap way is to get a manometer and a power vac or something.
Peak boost on the BA is 6psi @ 2500-3000rpm, but then it drops off to about 5psi until about 5800rpm. Id be interested in seeing the compressor flow maps before boosting it up. I can’t see ford giving out that info anytime soon.
