tastymudcrab Member 5 Member For: 17y 6m 6d Posted 15/08/07 09:14 AM Share Posted 15/08/07 09:14 AM whenever I make a right turn at speed I hear a scraping sound. 3 or 4 times it happens around each corner. sounds like the exhaust rubbing on something metal or the brake rubbing on something. I dont know much about cars to be sure though.sounds like "tsh tsh tsh tsh"! with it being louder if I turn harder and faster.thanks Jason Link to comment Share on other sites More sharing options...
PURVIE Sexy Member Donating Members 524 Member For: 18y 1m 22d Gender: Male Location: Berwick, VIC Posted 15/08/07 09:42 AM Share Posted 15/08/07 09:42 AM (edited) Hey Jason,From what it sounds like to me, it seems that the heat shield on the exhaust has become loose, hence the rattling. You can either tighten it, but the easiest would be to remove it, it'll probably take about 10-15 mins, all you'll need is a small spanner and tin snips.Cheers Edited 15/08/07 09:43 AM by PURVIE Link to comment Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 4m 5d Gender: Male Location: CH Posted 15/08/07 10:08 AM Share Posted 15/08/07 10:08 AM Might be a stone in ya hubcap..........Or a heat sheild like someone else said Link to comment Share on other sites More sharing options...
Chris xr6 Member 376 Member For: 20y 10m 2d Location: Shire Posted 16/08/07 12:37 AM Share Posted 16/08/07 12:37 AM Check your swaybar linkage hasn't broken Link to comment Share on other sites More sharing options...
Harves Member 20 Member For: 22y 10d Posted 16/08/07 04:22 AM Share Posted 16/08/07 04:22 AM Classic handbrake rubbing sound....Harves Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 4d Gender: Male Location: central coast Posted 16/08/07 04:46 AM Share Posted 16/08/07 04:46 AM handbrake is usually a more constant noise 'I would be checkin all the inner gaurds to see if there are any rub marks or lose panels 'what size wheels are running if their over standard might need your gaurds rolled a bit Link to comment Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 7m 23d Posted 16/08/07 12:07 PM Share Posted 16/08/07 12:07 PM Check your swaybar linkage hasn't brokenOr lose Link to comment Share on other sites More sharing options...
ShelZ Inactive Members 1 Member For: 17y 5m 18d Location: Penrith Posted 17/08/07 12:00 AM Share Posted 17/08/07 12:00 AM whenever I make a right turn at speed I hear a scraping sound. 3 or 4 times it happens around each corner. sounds like the exhaust rubbing on something metal or the brake rubbing on something. I dont know much about cars to be sure though.sounds like "tsh tsh tsh tsh"! with it being louder if I turn harder and faster.thanks JasonI've got the same problem on my car. Getting it checked out today by the pro's. If I find out will definately let you know today.Cheers Link to comment Share on other sites More sharing options...
ddonxr6t Member 3 Member For: 17y 5m 21d Posted 17/08/07 03:13 AM Share Posted 17/08/07 03:13 AM this handbrake noise what makes it happen? is it as simple as a handbrake adjustment I have that problem with my car Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 4d Gender: Male Location: central coast Posted 17/08/07 05:15 AM Share Posted 17/08/07 05:15 AM This is fords fix for it some people say it works some say it doesn't last long I've noticed with mine it seems to help if I go to the car wash and really give the brakes a good high pressure clean it stops the sound but I do it every weekbrakes.pdf Link to comment Share on other sites More sharing options...
