kenny Member 11 Member For: 17y 6m 21d Posted 15/08/07 03:53 AM Share Posted 15/08/07 03:53 AM Anyone know of the top of their head what the battery number is? Also what battery would u recommend? My stockie died and out of desperation I went to autobarn and got a centrury 57f I think it is.just a bit confused because I was told 380 or 540 from ford and different numbers from other placesmy stock battery the sticker which has all that stuff on it coroded off lol so it was hard to telldiscuss Link to comment Share on other sites More sharing options...
blu falc Member 43 Member For: 17y 7m 12d Posted 15/08/07 03:55 AM Share Posted 15/08/07 03:55 AM for that sort of money I would be getting an optima yellow top or oddessy battery Link to comment Share on other sites More sharing options...
kenny Member 11 Member For: 17y 6m 21d Posted 15/08/07 03:59 AM Author Share Posted 15/08/07 03:59 AM money? Link to comment Share on other sites More sharing options...
blu falc Member 43 Member For: 17y 7m 12d Posted 15/08/07 04:07 AM Share Posted 15/08/07 04:07 AM the optima yellow tops are cost price of around $240 for the normal size (physically). I know that most bigger car audio places can get them in and most battery places stock them. Knowing the cost price maybe go somewhere you can bargain. JB HiFi can get them in but probably won't have one in stock Link to comment Share on other sites More sharing options...
teeg Member 372 Member For: 19y 6m 2d Location: SA Posted 15/08/07 04:43 AM Share Posted 15/08/07 04:43 AM I think you will find he's talking cold cranking amps not $. Link to comment Share on other sites More sharing options...
blu falc Member 43 Member For: 17y 7m 12d Posted 15/08/07 04:49 AM Share Posted 15/08/07 04:49 AM (edited) I think you will find he's talking cold cranking amps not $.Edit- my mistake, I thought you mean't you were going to pay that muchhere's the specs on the optima I run if it's of any interestPERFORMANCE SPECIFICATIONS D34Voltage 12Cold Cranking Amps at 0°F 750Marine Cranking Amps, 32°F 870Reserve Capacity - minutes** 120Capacity (c/20 rate) - Amp Hours** 55Internal Resistance - Ohms .0028PHYSICAL SPECIFICATIONS D34Length(mm) 254Width(mm) 178Height(mm) 198Weight (min. Kg.) 19.5Type Post / Terminal SAE postBCI Group 34National Stock No 6140-01-457-5392 Edited 15/08/07 04:51 AM by blu falc Link to comment Share on other sites More sharing options...
Daniel Member 299 Member For: 21y 6m 8d Gender: Male Posted 15/08/07 08:16 AM Share Posted 15/08/07 08:16 AM I use a yellow top optimaCannot recommend it highly enough!Never fails me, can leave everything open, stereo going all day, lights on etc - still cranks perfect.When it fully charged it cranks like its on speed lol, love it.Worth every cent as they last for ages and have great warranty! Link to comment Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 4m 21d Location: Brissy Posted 15/08/07 08:28 AM Share Posted 15/08/07 08:28 AM (edited) Yep did some research on light weight Odessey batteries, but seams many many returns unhappy chappies, seams they dont hold a chrage long 2-3 days then drain dead, and lots dieing after 12mth, so then found the yellow top Optimas seam to be the go, long life very well regarded, expect to pay $250-$290 at the cheapest, but if your straped for cash and in Brissy just pop down to Self Serve spares at Wacol for $30 bucks pick one out of a scraped car, got one last week workin fine.P.S the numbers 330, 440 ect usually refer to Cold Cranking AMps, a 4ltr Falcon 6cly would usually rate about 400CCa. Edited 15/08/07 08:35 AM by Paranormal Link to comment Share on other sites More sharing options...
blu falc Member 43 Member For: 17y 7m 12d Posted 15/08/07 02:03 PM Share Posted 15/08/07 02:03 PM the one's you can pick up new for around $250 are the smaller yellow tops, unless your after the space or weight saving I would go the full sized yellow top. I ve got mine mounted in the boot so I can have the airbox on the turbo side and because they are a sealed gel battery you don't have to vent them to outside the car and you can mount them any way they fit (sideways, upside down ect.) Link to comment Share on other sites More sharing options...
