Best Cats
TUFXRT6
  • Replies 43
Posted Images
  • Member For: 17y 8m 21d
The best cat is the gutted cat. Get your local exhaust shop to remove and if they wont empty the insides out and refit it for $100 go somewhere else. Another way is go to the wreckers and take it home and do it yourself. Take your DIY hi flow cat to the exhaust shop and they should swap them over for $50. Most cats would be stuffed in 12mths if your running around 300rwkw. So long as it looks standard from outside you wont get into trouble with the law.
deny deny deny. Cats do collapse from time to time. The substrate also becomes inactive over time. If you get done all you get is a fail reading and you go buy a newie and fit it. No great drama
  • Member For: 17y 9m 26d
How does one go about gutting a CAT if say they wanted too.. ;)
I've heard the Punched CAT is the easiest. (meaning a pipe punched through the CAT and welded in).
Also how is the exhaust designed. Meaning how does it fit together and get removed.
Can you unbolt a section and work on it then reinstall? If so what part?
Hope that makes sense.
Edited by ritzy
  • Member For: 18y 7m 26d
I personally never want to go down the gutted or punched cat road.
Does any one know the pricing of the Catco 5" metalic, is it me or is that slightly overkill??
Regards
TUFXRT6 :tonguepoke:
  • Member For: 20y 3m 11d
I came across these guys that sell them for $440 http://www.justjap.com/parts_ncats.htm. The xforce one is just as good flowing apparently (metalic) and about $300 on ebay. www.catco.com.au has some comparisons. I think the benefit of these 2 cats is that they provide close to 0 restriction on a 3" pipe where the metal cat is about 10%. When it comes to performance sometimes it's worth paying a little extra
Edited by tquarrell
Cats are all the same on the inside. Surface area is what counts. Substrate is substrate. I have seen half dozen cut open and all use the same insides. Obviously the more surface area the better the flow.
  • Iconoclast
  • Member For: 20y 1m 18d
Cats are only valuable by there restriction, or more to the point the lack of it......... IE.. No cats = no static..
You want carbon credits though, PM me for the best buy cat on the market..........
