Octane Booster
  • <put funny sh*t here>
  • Member For: 18y 3m 24d
Hi all
Got a dyno day coming up tomorrow, and im running BP Ultimate 98 with my 10PSI tune.
Would running some octane booster as well as the BP Ultimate 98 make any difference performance wise, or will it be a lot safer when putting the car on the dyno with the higher octane level?
The dyno will be showing rwkw and torque, so I'll have no idea what the AFR is (so I want to play it safe)
  • Replies 27
Well that's what I thought.. but they had a meeting with the guys from BPT last night, and here is the outcome:
The dyno shootout mode will be used showing power in RWKW and Traction Torque. It is up to you to ensure your car is safe to run.
Kinda makes it sound like if the AFR is dangerous levels then tough luck?
So I sent him a PM saying how I'd like to see the AFR or have another run or something (even if I have to pay for it) to see the AFR and heres the response:
Barry said he was not sniffing to save set up etc. But speak to him yourself mate.
So I'm assuming the "sniffing" is when they clamp that attachment onto your exhaust...etc and that's used to get the AFR? Sounds like they wont even be recording the AFR at all?
Who knows... I'll find out tomorrow I guess?
Yeah I will do then! The main reason im worried is that my original fuel filter is un-removable (its like its welded to the fuel lines!).. so im worried its affecting some of the fuel flow. So running the octane booster might give me some peace of mind..
  • Formerly Turbo6
  • Member For: 22y 1m 25d
Mate, if your filter is restricting fuel flow, the thing will be running lean and no amount of Octane booster will supply more fuel to the engine?????? That is a mechanical fault!
IMHO don't use Octane booster for trying to raise your octane levels anyway. They have been proven to do Sweet FA and they are very effective in stuffing your very expensive spark plugs.
If you want higher octane, go and run a higher octane fuel e.g. Shell V Power Racing. It is rated at a minimum of 100RON. Adding Octane booster to a 98 RON fuel would be lucky to raise the RON level 2 whole points.
Just my practical experience with Octane booster and 2cents
Edited by F6 RAPID
Yeah im not trying to say it will make up for any potential fuel starvation due to a blocked filter, I just thought that if theres the same amount of fuel coming through but its got a higher octane rating then that means theres less chance of potential pinging.
I'm no expert on the issue, hence my questions :)
  • Member For: 20y 8m 23d
Perhaps the best thing to do is to get a custom tune for piece of mind before you stick it on a dyno and have some guy push it ten /tenths without knowing whats happening to your AFR's.
On the dyno days I've attended theres always been a couple of cars that have had their runs aborted due to AFR's showing up dangerously high.
