Phoontastic Donating Members 262 Member For: 19y 2m 26d Gender: Male Location: Canberra Posted 08/08/07 12:13 PM Share Posted 08/08/07 12:13 PM To all you knowledgeable dyno dudes, what gear should the ZF 6 speed auto be dyno tested in and why? I've heard different opinions and I'm wondering what the correct answer is, if there is one. Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/ Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 4m 30d Gender: Male Location: Brisbane Posted 08/08/07 12:35 PM Share Posted 08/08/07 12:35 PM Mine were done in 3rd gear from memory, got no idea about why though. Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562445 Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 19y 2m 26d Gender: Male Location: Canberra Posted 08/08/07 12:47 PM Author Share Posted 08/08/07 12:47 PM Yeh, mine too. I believe the manuals are usually done in 4th, but the ZF auto has mostly been done in 3rd. 4th in the auto is, so I'm told more like an overdrive, hence loads up the motor more than third, so I would have thought that 4th would be a more realistic test of a flat out run. Has anyone had a 4th gear dyno run in the ZF? Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562452 Share on other sites More sharing options...
Paul@eliteauto Member 843 Member For: 18y 7m 29d Gender: Male Location: Brisbane Posted 08/08/07 01:23 PM Share Posted 08/08/07 01:23 PM We do ours in 4th because it is direct drive. 1 is to 1.Nizpro do the same.Cheers Paul Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562464 Share on other sites More sharing options...
South Member 323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 08/08/07 01:23 PM Share Posted 08/08/07 01:23 PM You do a dyno run in whatever gears is closest to 1:1 ratio Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562465 Share on other sites More sharing options...
Billsta Member 355 Member For: 18y 9m 24d Location: Rolling on my 20's Posted 09/08/07 06:42 AM Share Posted 09/08/07 06:42 AM Definately 4th Gear, I coudn't see some of the boys running decent numbers do that to a ZF inlcuding mine at 420+rwkw. Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562638 Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 4m 17d Location: Sydney Posted 09/08/07 07:40 AM Share Posted 09/08/07 07:40 AM 4th is the prefered gear for tuners as it is the closest to 1:1, have also seen 3rd gear used on the ZF3rd is 1.52:14th is 1.14:15th is 0.87:1 Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562658 Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 19y 2m 26d Gender: Male Location: Canberra Posted 09/08/07 12:51 PM Author Share Posted 09/08/07 12:51 PM Thanks for all your replies guys. Ran up my new tune from Simon (XFT) at Gentech today using 4th gear and managed a bees dick over 400rwkw. I'm very happy with the tune, and it still drives like a stockie until you stick your foot into it.......and then holy snapping duck sh#t it takes off and pulls really strong all the way through to the top end. Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562830 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 5m 21d Gender: Male Location: Perth, NOR Posted 09/08/07 01:02 PM Share Posted 09/08/07 01:02 PM Geez what does the speed top at in 4th gear on the dyno??? it must be damn close to 200kph yeah?nice figure too mate!!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562837 Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 19y 2m 26d Gender: Male Location: Canberra Posted 09/08/07 01:09 PM Author Share Posted 09/08/07 01:09 PM Thanks mate. The new curves were run with RPM on the bottom axis. Old curves indicated 206kph from memory. Link to comment https://www.fordxr6turbo.com/forum/topic/37318-dyno-testing-the-6-speed-auto/#findComment-562841 Share on other sites More sharing options...
