  • Member For: 17y 11m 14d
Ok guys, got my Tripod holder and my gauges from Scott (cheers mate).......now I just need to know how on earth I get the wiring from the back down to the firewall......any suggestions ?????
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/
  • Here since the start...
  • Member For: 22y 1m 20d
Take the ICC out (only takes 5-10 mins if you know what you're doing) and everything will be much easier!
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/#findComment-560643
Oh dear... It's alot to post up!
I might have a better solution... Give me a minute.
Edit: Here we go...
BA Falcon Centre Stack Trim & ICC Removal Courtesy of FordForums :blink:
Where are you getting your power from?
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/#findComment-560647
So after a little discussion with Scott.....I decided that I should make a singular power and singular earth to all three gauges and use some form of connector to hook up all three guages to each and run the each individual sensor through to the respective units.......will tell you how I go..... =)
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/#findComment-560672
  • Member For: 19y 11m 8d
that's how I ran the power leads. hooked into the light for the cig lighter as it was not being used.
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/#findComment-560673
Scott's gauges have a jumper lead supplied with them to connect them all in series. The wiring is all there. Just run power into the gauge on the right hand side and run the jumper leads to the other two.
You can get accessory power and an earth from the power source socket wiring. Illumination can be found on the smokers pack light plug. This loom will be taped to the power source wiring if you don't have the smokers pack. Constant power can by found on the mobile phone plug behind the fuse panel. That same plug also has accessory power and earth.
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/#findComment-560695
that's what I ended up doing....but god damn it was fiddley =) All good now....just gotta hook the sensors up and it's all done =) (but now my Cruise Control is playing up =( )
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/#findComment-560932
  • Uncle Bulgaria was gender challenged
  • Member For: 21y 1m 26d
Does the illumination on the power source socket dim or not?
I know it says in the instructions to connect to a non-dimming source..
https://www.fordxr6turbo.com/forum/topic/37176-gauge-wiring/#findComment-560962
