dazxr6t Member 11 Member For: 17y 3m 11d Posted 03/08/07 11:23 AM Share Posted 03/08/07 11:23 AM in my ba xr6t when using 2/3 throttle or more and when the tacho hits 4000 or so,the car goes into some sort of limp mode. the car sounds like it drops 2 or 3 cylinders and keeps going like this for about 3 or 4 seconds then the engine goes back to normal. also once it does this if I stab the throttle to the floor and release it the engine instantly goes back to normal. anybody got any ideas about what could be causing this frustrating problem because just as it's about to become fun it cuts out. the engine doesn't stall and it doesn't happen unless you give it a decent amount of throttle. it's ok up to about 2/3 throttle. thanks darren 1 Link to comment Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 2m 21d Location: Brissy Posted 04/08/07 02:38 AM Share Posted 04/08/07 02:38 AM Try new plugs, unless it's edited and you've flashed in the 4000rpm valet tune. Link to comment Share on other sites More sharing options...
dare Member 7 Member For: 19y 9m 7d Location: Country WA Posted 05/08/07 06:50 AM Share Posted 05/08/07 06:50 AM Darren, had similar problem late last/early this year. Started playing up, same as yours, at 4000rpm intermittently on medium to heavy throttle, then more regularly ->3500rpm, then 2500rpm. Ended up being corrosion in the connector to the knock sensor, leaning it out and going into limp mode 'til it adjusted itself. All came up as errors (with explanations) when fraud mechanic finally believed me and connected diagnostic to computer - I looked over his shoulder quite interesting. I put up with it for quite a while but problem got to the point of leaning out to the extent of stalling when under load towing boat, so not good - a quick clean of the connector and not a problem since. Hope this help at all.Cheers Simon Link to comment Share on other sites More sharing options...
dazxr6t Member 11 Member For: 17y 3m 11d Posted 06/08/07 01:24 AM Author Share Posted 06/08/07 01:24 AM thanks guys. the car is going into chip torque on friday to run it up on the dyno to see what shows up I'll definetely make sure I mention these suggestions. I'll let you know what the outcome isthanksdarren Link to comment Share on other sites More sharing options...
dazxr6t Member 11 Member For: 17y 3m 11d Posted 06/08/07 01:29 AM Author Share Posted 06/08/07 01:29 AM actually while I'm here can someone tell me where the knock sensor is located and I'll check it myself first. might save me $200 which I can put towards my flash tuner.thanksdarren Link to comment Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 18y 9m 8d Gender: Male Location: The Shire Sydney AUS Posted 06/08/07 01:34 AM Share Posted 06/08/07 01:34 AM Could also be your valve springs, If it was plugs it was just be spluttering up top and it won't continue on for 3-4 secs How much power you running! Link to comment Share on other sites More sharing options...
dazxr6t Member 11 Member For: 17y 3m 11d Posted 06/08/07 06:21 AM Author Share Posted 06/08/07 06:21 AM only bought the car 1 week ago but assume it's standard. don't think it's valve springs because if I stab the throttle when it goes into "limp mode" and let it off again instantly it sort of resets the computer or something because the car goes back to normal. if I don't do that it takes the normal 3 to 4 seconds to reset itself so I would probably rule out something mechanical otherwise the throttle stab wouldn't make an instant difference I wouldn't think. this leads me to think that it's something electical/computer. as soon as I find out where the knock sensor is located I'll check that as a previous poster suggested because this sort of thing seems to make sense to me but please keep the suggestions coming because they are appreciated.thanksdarren Link to comment Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 2m 12d Gender: Male Location: NSW Posted 06/08/07 02:54 PM Share Posted 06/08/07 02:54 PM Could be some sort of anti hoon thing?Get it flashed. Link to comment Share on other sites More sharing options...
dazxr6t Member 11 Member For: 17y 3m 11d Posted 10/08/07 05:23 AM Author Share Posted 10/08/07 05:23 AM just had the car on the dyno at chip torque. the problem was that someone has played with the actuator on the turbo. whatever they did caused the boost to spike at around 13 psi for a short period of time. the car actually had 150 rwkw at 3000 rpm with hardly any throttle. I said to the guy that's pretty crap power and he said for the amount of throttle he was using it was pretty bloody good. what chip torque did to fix it was bypass the boost control solenoid. this somehow by some computer wizardry dropped the boost back to a more ECU acceptable 7 psi. no more overboost limp mode. the car now goes straight to 6000 rpm or so. the problem with all this is that before when I got on the gas from 20 or 30 km/h it would plant you in the seat very hard and start to wheel spin. it made the car feel very quick up to around 4000 rpm but then it would cut out. now it feels soft more like I expected an xr6t to feel like when I bought it. so I'm happy that it's now running properly but disappointed that I've lost that shove in the back I used to get. at the end of the day the car has to be faster a-b but I want my wheel spinning power back. I asked about getting another actuator to make it standard again then flashing it but they said to leave it as is then they will do a custom flash tune to suit the actuator as it is and should probably get a little more horsepower than if I was to start with the standard one. thanks to those that tried to help me it was appreciated. suppose I'll just have to save for a flash tune now and see if that's enough to satisfy. if not goodbye bank balance for a little while.thanks darren Link to comment Share on other sites More sharing options...
XR6Turbine Member 9 Member For: 17y 2m 16d Posted 03/09/07 06:49 AM Share Posted 03/09/07 06:49 AM (edited) Mate I feel for ya. I had the EXACT same problem xept mine was a stuffed wastegate that allowed boost to build to 15psi then WHAM, limp mode. But boy when it was building it was like a rocketship. So, I just can't go backwards. Got a CAPA box, big cooler, injectors, and a zuast stitting in my shed waiting for a few more $$ to fund the custom tune. Hopefully, I will get that absolutley fantastic rush back!! Edited 03/09/07 06:50 AM by XR6Turbine Link to comment Share on other sites More sharing options...
