01txr Member 861 Member For: 18y 5m Gender: Male Location: QLD Posted 01/08/07 08:44 AM Share Posted 01/08/07 08:44 AM I have a set of Argo rods and am wanting to know what people have used and what there feedback has been on the pistons of choice and also what rings I should use.However I will not use acl piston's ever again after 3 different engines I know of have all broken the ring lands, and these engines where non blown.keep in mind I will be looking at near to 450rwkw out of this with the lowest boost to achieve it. Link to comment https://www.fordxr6turbo.com/forum/topic/37117-piston-selection-to-fit-argo-rods/ Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 1m 23d Gender: Male Location: stanthorpe wine capital of qld. Posted 01/08/07 07:43 PM Share Posted 01/08/07 07:43 PM cp pistons are great use them all the time.Ian Link to comment https://www.fordxr6turbo.com/forum/topic/37117-piston-selection-to-fit-argo-rods/#findComment-560403 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 5m Gender: Male Location: QLD Posted 04/08/07 01:41 PM Author Share Posted 04/08/07 01:41 PM What price are they and where do you suggest I purchase from?You have used them on the Argo rods?How are they for noise?And what boost and power can they handle?I will be also looking for a trustworthy good engine builder to build and fit it as I have not the time to do it at present.Can you give me any name's for this that are located South QLD? Link to comment https://www.fordxr6turbo.com/forum/topic/37117-piston-selection-to-fit-argo-rods/#findComment-561196 Share on other sites More sharing options...
Master G Donating Members 511 Member For: 21y 7m 23d Gender: Male Location: Sydney NSW Posted 04/08/07 02:26 PM Share Posted 04/08/07 02:26 PM As Goldie mentioned, CP pistons. Running the same combination in my car.RegardsM G Link to comment https://www.fordxr6turbo.com/forum/topic/37117-piston-selection-to-fit-argo-rods/#findComment-561214 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 5m 22d Gender: Male Location: Perth, WA Posted 04/08/07 03:25 PM Share Posted 04/08/07 03:25 PM I have tried CP pistons, and heard a few cars with them, and if you like a mechanically quiet engine, well I wouldn't use them again My latest engine build use Atomic 'Fat Rods' and Mahle pistons, and though not quite stock sounding, it is pretty close.I have built a 2nd engine for R_UTE, also using Atomic rods and Mahle pistons, and the results are the same, pretty quiet.Pistons are rated just over 100 kw per cylinder (650 kw total, which is 860 hp) so that will suffice for most.Hope this helps Link to comment https://www.fordxr6turbo.com/forum/topic/37117-piston-selection-to-fit-argo-rods/#findComment-561219 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 5m Gender: Male Location: QLD Posted 05/08/07 12:52 PM Author Share Posted 05/08/07 12:52 PM Thanks ninka.Don't want a rattly sounding engine.Do the CP's only rattle when cold or all the time.How much where the Mahle's and where do you suggest to purchase?Are these the same brand as the oem gen3 pistons?Just that when I worked at zupps these where the piston ordered for replacement in batch's every week.May have been a better piston to replace the original crate engine's poorly machined versions.Does Federal Mogal (TRW) do a piston to suit? Link to comment https://www.fordxr6turbo.com/forum/topic/37117-piston-selection-to-fit-argo-rods/#findComment-561509 Share on other sites More sharing options...
Master G Donating Members 511 Member For: 21y 7m 23d Gender: Male Location: Sydney NSW Posted 06/08/07 02:00 AM Share Posted 06/08/07 02:00 AM (edited) I have had the CP pistons in now for over 4 months and there are no rattles at all. Car sounds stock at idle. Under acceleration, too hard to know over the induction noise RegardsM G Edited 06/08/07 02:00 AM by Master G Link to comment https://www.fordxr6turbo.com/forum/topic/37117-piston-selection-to-fit-argo-rods/#findComment-561584 Share on other sites More sharing options...
