AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 8m 16d Gender: Male Location: Canning Vale, W.A Posted 29/07/07 01:52 PM Share Posted 29/07/07 01:52 PM Hey guys im just in the middle of taking off my front bar and im having a bit of trouble taking off the black screw/cap thingys in the wheel arches, is there any trick to getting them off?and as for the fog lights do they just pop out or what.Is there a guide at all that anyone could share with me?Cheers. Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 11m 20d Gender: Male Location: Perth, WA Posted 29/07/07 01:55 PM Share Posted 29/07/07 01:55 PM The scrivets are difficult to get out, so basically cut them with a Stanley knife to save time, or if you want to unscrew them, then use a very small screwdriver blade and a Phillips head screwdriver, hold the outside of the scrivet head, while turning the P.h. screw in the scrivet, without pushing, and try to get the screwdriver blade in between the main body and the head of the scrivet while turning it, and with a bit of luck you should be able to leverage it out.Fog lights have a connector which just disconnects, but getting the lights out of the bumper is by some pretty strong plastic clips, so takes a bit of work, but not too difficult. Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 8m 16d Gender: Male Location: Canning Vale, W.A Posted 29/07/07 02:07 PM Author Share Posted 29/07/07 02:07 PM Thanks for that Alan.Looks like its a tomorrow after work job now though, as I'm off to bed haha. Link to comment Share on other sites More sharing options...
aussieturtle Member 39 Member For: 17y 4m 24d Gender: Male Location: Sydney Area Posted 10/08/07 05:39 PM Share Posted 10/08/07 05:39 PM Hey guys im just in the middle of taking off my front bar and im having a bit of trouble taking off the black screw/cap thingys in the wheel arches, is there any trick to getting them off?and as for the fog lights do they just pop out or what.Is there a guide at all that anyone could share with me?Cheers.Hi,1. Remove the black undertray by removing the bolts and scrivets. (Dont forget the one in the center at the back behind the lip).2. Remove the 4 big scrivets on the top of the radiator support and lift the edge of the top tray(above the grill where the secondary bonnet release is). This will uncover the 2 top bumper bar bolts - take them out.3. Remove the 2 scrivets and 1 self tapper from each splashguard in the wheel arch.4. Grip the bumper at the back corner next to the guard on the drivers side and pull out - this does take a little effort to release the bumper from the clip. Repeat this on the passenger side.5. Move around to the front and grip the bumper top and bottom and ease it away from the car.6. Sit the bumper down gently and disconnect the fog lamp plugs(or use an assistant if the car is on stands). You can disconnect the plugs as step 2 if you wish if the car is raised - I cant get my melon under there if it is on its wheels :-).As for the scrivets - you need to slip a screwdriver under the edge to stop them from spinning whilst unscrewing the center pin. When the center pin is about 3/16" out you should be able to remove the whole thing. If you cant - grab a safety razor and cut the top off the whole thing. They are available for next to nothing from Ford Spares - or for a little more money you can get them in a 2 unit blister pack from any disreputable auto accessory shop :-).It is not as intimidating as it looks and once you have done it the first time it will only take about 15 minutes to do next time.Good luck with it.Tom Link to comment Share on other sites More sharing options...
Ghia Member 191 Member For: 22y 5d Gender: Male Location: Aus.Vic.Melb Posted 10/08/07 11:28 PM Share Posted 10/08/07 11:28 PM Whats everyones thoughts on re-fitting the undertray.When I did my cooler I ran out of time and haven't put it back on yet, what real useful purpose does it serve. Or in otherwords, convince me that it needs to go back on Link to comment Share on other sites More sharing options...
boost26 Member 51 Member For: 17y 7m 12d Gender: Male Location: Melbourne Posted 11/08/07 04:59 AM Share Posted 11/08/07 04:59 AM Whats everyones thoughts on re-fitting the undertray.When I did my cooler I ran out of time and haven't put it back on yet, what real useful purpose does it serve. Or in otherwords, convince me that it needs to go back on I would suggest refitting it. One of the reasons for the undertray, if you have a good look at the way its designed is it directs most of the air coming from the bottom opening of your bumper through the intercooler. Link to comment Share on other sites More sharing options...
aussieturtle Member 39 Member For: 17y 4m 24d Gender: Male Location: Sydney Area Posted 13/08/07 08:22 PM Share Posted 13/08/07 08:22 PM Whats everyones thoughts on re-fitting the undertray.When I did my cooler I ran out of time and haven't put it back on yet, what real useful purpose does it serve. Or in otherwords, convince me that it needs to go back on Hi,It also provides structural rigidity.Cheers Link to comment Share on other sites More sharing options...
Ghia Member 191 Member For: 22y 5d Gender: Male Location: Aus.Vic.Melb Posted 14/08/07 02:42 AM Share Posted 14/08/07 02:42 AM I would suggest refitting it. One of the reasons for the undertray, if you have a good look at the way its designed is it directs most of the air coming from the bottom opening of your bumper through the intercooler.Hi,It also provides structural rigidity.CheersOk, thanks guys - I'm convinced. Back on it goes. Link to comment Share on other sites More sharing options...
