camerooch Member 129 Member For: 21y 11m 21d Location: Melbourne Posted 12/06/03 03:10 AM Share Posted 12/06/03 03:10 AM Anyone had any vibrations through the driveline, starts at approx. 70kph & progresively gets worse up through au to 120kph & up.Real drama at the moment - need to get it fixed !! Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/ Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 22y 17d Gender: Male Posted 12/06/03 03:23 AM Share Posted 12/06/03 03:23 AM that's not XRCISM is it Cam?? (check the sump for a bolt head or nut (not kidding)... is it like a harmonic type resonance?) Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-28194 Share on other sites More sharing options...
camerooch Member 129 Member For: 21y 11m 21d Location: Melbourne Posted 12/06/03 03:33 AM Author Share Posted 12/06/03 03:33 AM No, but we can create one if you like ??!!!!Have you heard of the bolt issue before ??? Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-28197 Share on other sites More sharing options...
Guest DEVO Guests Posted 12/06/03 03:52 AM Share Posted 12/06/03 03:52 AM I have a similar thread elsewher asking about a clunking in the suspension and gearbox- I wonder if this may be related? I have had some vibration type feelings but usually attribute it to bad Brisbane roads :lol: Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-28201 Share on other sites More sharing options...
1axr TEAM BLUEPRINT Member 913 Member For: 22y 3m 8d Location: Perth W.A. Posted 12/06/03 04:00 AM Share Posted 12/06/03 04:00 AM I have had the vibrations, but put it down to the tyres.I must have been close to the spot cause my dealer fitted new tyres at 5000 ks Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-28204 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 5m 29d Gender: Male Location: Dé·jà vu Posted 12/06/03 04:10 AM Share Posted 12/06/03 04:10 AM I'll put my hand up for this one had it before the last service at Westpoint, now seems to have disappeared.Dont know if it's just me but every now and then I think it comes on but not as bad.It does feel harmonic.Called the service department after a couple of days as I had noticed it was gone, they couldnt recall and had no info as to what was fixed if anything. Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-28208 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 1m 26d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 13/06/03 02:12 AM Share Posted 13/06/03 02:12 AM Me thinks I may have this, as already mentioned the roads around brissy are sh*tty. But between 100 - 120 it's quite apparent.Will be getting it checked out sooner or later.Scotty. Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-28514 Share on other sites More sharing options...
camerooch Member 129 Member For: 21y 11m 21d Location: Melbourne Posted 14/06/03 03:12 AM Author Share Posted 14/06/03 03:12 AM Have tried a few more things, seems like it may have been from the I.R.S suspension, de-stressed it all, went for a drive, seems a bit better - will keep you all posted. Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-28726 Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 22y 17d Gender: Male Posted 21/06/03 10:49 AM Share Posted 21/06/03 10:49 AM Cam ... was that a ute with the driveline vibration ?I was told of an experience of a ute that was shaking itself to death at speed ... it was nearly impossible to dyno ... they said the rear axle was probably siting up under load and the drive-shaft became eccentric .... an age old problem with live axles..no .. it wasn't a ute ... IRS ... duhh ... oh well ... sounds like it may have been fixed but have you heard of any ute problems? Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-30418 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 1m 26d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 03/07/03 11:58 AM Share Posted 03/07/03 11:58 AM End of financial year clearance,got my tigers rotated & balanced before the end of '03 financial year, thought I might get "little johnny" to pay a percentage. Picked it up afterwards & off I went without paying much attention. Gave her once over with the sponge next day to reveal an interesting fact. The tyre on the front right has had the 75 gram factory balance weight removed completely. Marks can be seen where it was located & I think one of the other wheels have had its weights shifted. This I believe will have been the culprit of my highway vibration, the officer in charge of finance drove "T" to Gympie (hell town) on the weekend & reckoned she's smoother than some of my 1 liners, not all of 'em though.I had always been alarmed at the amount of weight on brand new wheels & tyres that "T" had & now it seems it was justifiably so! For the small cost associated with it I would recommend people experiencing any vibration to seek outside advice, a balance & an alignmentScotty Link to comment https://www.fordxr6turbo.com/forum/topic/3704-driveline-vibration/#findComment-33492 Share on other sites More sharing options...
