Which Mods In What Order Out Of The Following...
gilto
  • Member For: 17y 6m 21d
Hi everyone,
It's come time to do some mods and I have some ideas. Out of the following what order would you suggest...money is a big issue here as I don't have an open cheque book unfortunately...
Anyways here is what I had in mind...what stages would be 1, 2, and 3 and approximately what power would your combo make?? Am I missing anything from the list you would also recommend??
CAI
K & N Filter
Fuel Pump
Injectors
Edit
CAT
Valve Springs
Here is what I thought...will be interesting to see if people agree or disagree..
Stage 1
Edit + Injectors
Stage 2
Edit + Injectors + CAI + K&N Filter + CAT
Stage 3
Edit + Injectors + CAI + K&N Filter + CAT + Valve Springs + Fuel Pump
Thanks guys!
  • Member For: 19y 6m 12d
You could do the CAI and Filter before the edit as a retune is not required when you fit them.
Once you have all this fitted I would guess around the 300kw mark.
A good intercooler at this point would be a good Idea.
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 6m 28d
Stage 1 untill you can afford to do the IC, exhaust,valve springs,pump and actuator
CYA JEFF :spoton:
  • Member For: 18y 9m 26d
im going to have to agree with dboss on this one.
get the injectors and the edit first, if u can get the airfilter and cai done before the first edit.
then when you can afford the rest do it all at once in 2 stages, this will save $$ for the second tune.
  • Member For: 19y 6m 30d
if you know that you want to do all those mods, do it all in one step. Obviously it means you'll have to wait longer, but at least you won't need to spend extra money for each tune... on the other hand, if you'll be happy with edit/injectors for a while, then do that. Then 6-12months down the track do the rest. If you think it'll only be a matter of a month or so between changes, I'd be saving up and getting it all done at once.
I wish I had done it this way, saves some hassles.
Guest dico2020
  • Guests
this is my order (none fitted as yet)......
semen deka's
p/west plenum/cooler
capa flash tuner
still need------
high flow cat/zorst
springs
pump
then later----
rods n' forgies :innocent:
anyone wanna guess how many rwkw in chasing?
