  • Member For: 17y 11m 1d
I attempted replacing my fuel filter today. For the love of god, I just couldnt get it loose. I managed to get the rear nut loose, and that was using a larger adjustable spanner of all tools. The front one now has a rounded nut. I even resorted to vice grips but that failed as well! I cut a section of my 14mm ring spanner to try and get a good fix on the nut and that even stripped it. Tomorrow I will try the local ford wrecker for a new pipe.
  • 1 month later...
  • Oh look.... a real car, with no hair dryer
  • Member For: 18y 8m 4d
Thought I better finally get off my arse & replace the filter on my beast today.
Easier than I thought, the whole job took about 15 mins including jacking the car up so I could fit under it.
I used a Ryco filter & guess what no leaks.
By the way my old filter was engraved 11-5-06 & initialed T+M. I know its a long shot but anyone from here?
  • Member For: 16y 7m 10d
Yeah I replaced my fuel filter when I bought my car. my mate blew on the end of the used filter it and I couldnt believe how much black crap came out of it. also replaced it on my fairmont and same thing it leak at first and had to nip it up.
  • 2 weeks later...
  • Member For: 16y 3m 13d
I had same issue the other night when I went to change mine got the rear nut off but the front was :stupid: tight as only difference was I stopped before I rounded the nut :nono: I take it the rest of you guys didnt have the same issue? any suggestions?
  • Member For: 16y 10m 5d
got my filter replaced as well. I couldnt believe the black crap that came out of the old one (looked original).
New filter has made a car feel more responsive and also not as rough in the mornings. happy days
  • Member For: 19y 9m 22d
  cunno_01 said:
I had same issue the other night when I went to change mine got the rear nut off but the front was :crybaby: tight as only difference was I stopped before I rounded the nut :drunk: I take it the rest of you guys didnt have the same issue? any suggestions?
I had to give mine a good dose of wd40, left it for a minute and it came off much easier.
  cunno_01 said:
I had same issue the other night when I went to change mine got the rear nut off but the front was :spoton: tight as only difference was I stopped before I rounded the nut :beerchug: I take it the rest of you guys didnt have the same issue? any suggestions?
The forward part of the fuel line is easily replaced as its only a few ft long to the quick disconnect fittings where the pipe turns into a hose for engine changes. I gave up and went to the wreckers and got another pipe! Interestingly to note, the pipe from the wreckers was a different colour from a BA, myne a BF. The BA line screwed on easily.
  • 2 weeks later...
  • Hey guys, Tab is here... Oh i feel sick
  • Member For: 16y 10m 22d
hey how long do these fuel filters last? I had mine done last service which was 20,000kms ago, march last year. am I due for a change?
  • It's not a MKI!
  • Member For: 16y 9m 26d
From memory the manual says 100k, but most people halve the recommendations in the manula for everything anyway.
Every 10-15k is overkill in my opinion.
Unless you know you've had a bad batch of fuel, then do it more frequently.
