hanra Into the laaaake Member 1,532 Member For: 17y 5m 19d Gender: Male Location: Nrth Qld Posted 29/12/07 07:34 AM Share Posted 29/12/07 07:34 AM Carby Cleaner, Nulon Part No NC400 $10 (This is to clean out the oil screen and the Throttle Body)Waiting on the Spark plugs to come in. I'm not going to be doing all of these every service, butMate, I would strongly suggest to replace the Turbo oil line filter assy. Yes you can clean it, but I did a lot of work to clean mine out just as an experiment. I tried carb cleaner and a few other chemicals, I also put it through the ultrasonic cleaner at work. Under a strong microscope the oil screen still has fragments of metal stuck in it. The part is like 50 bucks. Just replaced it. Wat shop dosnt have NGK BKR6EIX in stock? Pre gapped to .75mm mate. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 1d Gender: Male Location: SoR, WA Posted 29/12/07 10:24 AM Author Share Posted 29/12/07 10:24 AM Mate, I would strongly suggest to replace the Turbo oil line filter assy. Yes you can clean it, but I did a lot of work to clean mine out just as an experiment. I tried carb cleaner and a few other chemicals, I also put it through the ultrasonic cleaner at work. Under a strong microscope the oil screen still has fragments of metal stuck in it. The part is like 50 bucks. Just replaced it. Wat shop dosnt have NGK BKR6EIX in stock? Pre gapped to .75mm mate.Hi mate,Could you or anyone else tell me the ford part number for the oil screen assembly?CheersAdrian Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 21y 11m 11d Gender: Male Location: Brisbane Posted 29/12/07 10:39 AM Share Posted 29/12/07 10:39 AM If I have it written down properly, it is: BA 9P424 A Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 5m 19d Gender: Male Location: Nrth Qld Posted 29/12/07 10:47 AM Share Posted 29/12/07 10:47 AM (edited) BA9P424A $65.14 incl GST.Its a terrible job to do. Heres a guide. http://www.fordxr6turbo.com/forum/index.ph...o+filter+screen Edited 29/12/07 10:49 AM by hanra Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 1d Gender: Male Location: SoR, WA Posted 29/12/07 11:07 AM Author Share Posted 29/12/07 11:07 AM Thanks mate. Link to comment Share on other sites More sharing options...
poita85 Donating Members 43 Member For: 17y 1m 28d Gender: Male Location: Wodonga, VIC Posted 11/02/08 11:33 AM Share Posted 11/02/08 11:33 AM Hi all, just wondering how you guys went about changing the fuel filter? I had a look at mine this arvo and was going to do it, but the bracket around the filter looks like it is riveted on. It also looks like the fuel lines would get in the way of the filter if you just undone the filter and tried to slide it out of the bracket. I didn't want to try it only to find out I would have to bend the fuel lines to get the filter out so just curious to how you all went about it. I'd rather drill the rivet out and get it that way, but the thing is a pain in the ass to get right under!Thanks. Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 5m 19d Gender: Male Location: Nrth Qld Posted 11/02/08 11:45 AM Share Posted 11/02/08 11:45 AM I just undid the fittings off the filter and moved the fuel line out of the way and the filter just slips out of the metal bracket. No drilling or bending required. Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 16y 10m 16d Gender: Male Posted 24/02/08 10:53 AM Share Posted 24/02/08 10:53 AM Hi guys, I will change mine too. Where do I buy a fuel filter from and how much are they? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 11d Gender: Male Location: Perth Posted 24/02/08 11:31 AM Share Posted 24/02/08 11:31 AM Make sure you get a motorcraft ag 55 aa not a ryco z373. I fitted a ryco to my ute the other day and the threads wearn't cut deep enough to allow the tapers on the fuel lines to seat properly. Thusly $1.50 premo all over the floor on start up. The motorcraft is about $1.50 more at trade price so about $15.Luke Link to comment Share on other sites More sharing options...
XRPete Member 673 Member For: 17y 2m 23d Gender: Male Location: Here Posted 25/02/08 10:10 AM Share Posted 25/02/08 10:10 AM Hi guys, I will change mine too. Where do I buy a fuel filter from and how much are they?Gee your good at digging up old threads Link to comment Share on other sites More sharing options...
