  • T.P.I.S.
  • Member For: 20y 6m 10d
Hi Guys,
Today I took my car into Ford for a service and I had them change my fuel filter which has never been done since new (60K ago).
What a huge difference. So much stronger up top now.
I think ill be doing it more often.
Cheers
Adrian
  • Member For: 19y 24d
Good stuff... there's cars around that have had a new, high flow pumps fitted but still have the orig filter lol
Edited by RAP1D
  • Into the laaaake
  • Member For: 17y 11m 30d
This was all part of the major service I did to my XR6T after I bought it 3 weeks ago with 50k on the clock.
For the last 3 weekends ive done,
Fuel Filter
Diff Oil
Trans Fluid incl Convertor
Engine Oil
Oil Filter
Spark Plugs
Clean/Re-oil K&N Air Filter
Clean TB
Relube wastegate solenoid
Fit Aux trans cooler
Replace radiator
Fix saggy front bumber
Wax the Paint
Blah Blah Blah Blah.........
  • <put funny sh*t here>
  • Member For: 18y 7m 5d
Excellent, ive heard of stories about the fuel filters before, getting clogged up with little black plastic 'hairs' from the inside of the fuel tank (when they make them in the moulds).
I'll have to do a bit of research into it to see where it is exactly, to change it on the weekend perhaps.
  • Into the laaaake
On my ute its basically in line with the passenger door, on the inner side of the chassis rail.
Piece of piss to replace.
  • Member For: 18y 25d
  FastR1Red said:
Where is it on the sedan?? I'll do mine as well.
Thank ya.
nearly the same place, but near the lhs rear passenger door.. just like the utes - it is on the inner part of the rail... you will need 2 spanners to undo it... takes 5 minutes..
cheers.
Edited by BA XTC
  • Member For: 20y 1m 12d
cheers.
Excellent, thanks BA XTC, I'll check it out on the weekend.
Edited by FastR1Red
