built2redline Member 187 Member For: 19y 9m 11d Location: sh*tney Posted 18/07/07 08:55 AM Share Posted 18/07/07 08:55 AM well its been at least 8 months since the motor threw a rod. so I think it was about time id show it some attention and get around at repairing it.pulling it appart I found thisand thisam I right in thinking that the white coating on the valves and on the inner turbo means that the car was running lean? Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 18y 15d Posted 18/07/07 09:18 AM Share Posted 18/07/07 09:18 AM yep, that cylinder looks VERY lean... the other valve next door lookd fine though... maybe faulty injector on that cylinder? Link to comment Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 2m 17d Gender: Male Location: Brisbane Posted 18/07/07 11:14 AM Share Posted 18/07/07 11:14 AM What have you been driving in the meantime? Link to comment Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 7m 26d Gender: Male Posted 18/07/07 12:03 PM Share Posted 18/07/07 12:03 PM might be a stupid question.. but why is it white when its lean?oxidizing? Link to comment Share on other sites More sharing options...
Chris xr6 Member 376 Member For: 20y 10m 18d Location: Shire Posted 18/07/07 12:12 PM Share Posted 18/07/07 12:12 PM The higher heat burns all the carbon of the valves etc.... Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 24d Gender: Male Location: Perth Posted 18/07/07 01:49 PM Share Posted 18/07/07 01:49 PM could also be a sign of coolant entry into the combustion chamber that tends to steam clean everything as well. Unlikely that you would get it in the exhaust side tho. My turbo was the same color as this when i pulled me engine down. I don't think its unusual as they run at some pretty high temps. Link to comment Share on other sites More sharing options...
built2redline Member 187 Member For: 19y 9m 11d Location: sh*tney Posted 19/07/07 08:52 AM Author Share Posted 19/07/07 08:52 AM all the valves are white, the ones to the left look darker cos of the shaddow from the flash.. they look very white and it wasnt from coolant bleaching as the cooling system was full and never had been topped up.the spark plugs were also white at the tip.. I thought these engines had multiple knock sensors that would retard the ignition in order to keep the engine safe.unless the tuner turned the sensors off. which I dont think he did Link to comment Share on other sites More sharing options...
built2redline Member 187 Member For: 19y 9m 11d Location: sh*tney Posted 21/07/07 10:21 AM Author Share Posted 21/07/07 10:21 AM ok pulling the engine out I found some scorched wiring in the top left hand corner that plugs into this sensor...what does this sensor do? is it a knock sensor? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 24d Gender: Male Location: Perth Posted 21/07/07 01:01 PM Share Posted 21/07/07 01:01 PM (edited) ok pulling the engine out i found some scorched wiring in the top left hand corner that plugs into this sensor...what does this sensor do? is it a knock sensor?Thats a cam position sensor. The knock sensors(s) are on the lhs of the engine down under the inlet manifold. The are round with a bolt directly in the centre of them. Damaged wiring on th cam phasing posi sensor is pretty common. Ps...luurrve the "shackle" on the rear engine lifting eye. Edited 21/07/07 01:02 PM by hiddeous Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 18y 15d Posted 21/07/07 01:11 PM Share Posted 21/07/07 01:11 PM well if she was all white then id suspect your running lean for sure... running lean doesnt gaurantee ping or det though, and may not be the cause of your dead engine, only increases the liklihood... goin full forged now eh? Link to comment Share on other sites More sharing options...
