FastR1Red Member 360 Member For: 19y 10m 1d Gender: Male Location: Mt Waverley Posted 17/07/07 10:57 AM Share Posted 17/07/07 10:57 AM XF,,,,,If you have a look on the left side where there's a self tapper holding the mesh in, just under that is a bolt. The plate, about 50 or 60mm long and 25mm wide, should have a small hole drilled in to one end. You mount it onto this bolt and it protrudes out to hold the bumper up. The one I saw was bent slightly to hold the bar up. You adjust the bend to suit how far you want the bar lifted.Both sides have the same bolt in the same position. Mate, sorry I can't be more help.I might be able to get some pics over the weekend to post. Link to comment Share on other sites More sharing options...
billsxr6t Member 10 Member For: 18y 30d Location: Perth (morley) Posted 21/07/07 02:14 PM Share Posted 21/07/07 02:14 PM mine was the same I just put two self tappers on the upper section in the lower mouth of the bumper hold it in position n drill some holes then just scew into place looks great n isnt going anywherep.s I had no gap at wheel end but as it went towards the headlight it got huge lol was really annoying will take pics tomorow n post upbill Link to comment Share on other sites More sharing options...
Locomick AK47's for everybody Donating Members 131 Member For: 18y 11m 22d Gender: Male Location: somewere Posted 21/07/07 04:10 PM Share Posted 21/07/07 04:10 PM this is wot I did , I put two studs in the lower part of the bumperhereand hereu will have to get down and mark were u wont the studs on the two little tab thingo's.now take the bar off and drill the holes in the tab's first.then put the bar back on and senter punch the steel cross member thru the hole's.now take the bar back off (if u dont do this u will make the holes to big in the plastic) now get a tap and matching drill bit ( for the tap that is ) then drill the holes in the cross member and tap them out.put the bar back on and screw the studs in.see no more gap's mick Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 8m 16d Gender: Male Location: Nrth Qld Posted 22/07/07 04:39 AM Author Share Posted 22/07/07 04:39 AM Great tip. I did the same thing just now and it worked a treat!!!!! NO MORE SAGGY BUMPER!!!!!!! Link to comment Share on other sites More sharing options...
Chief_XR6T Member 425 Member For: 17y 10m 26d Gender: Female Location: Adelaide Posted 04/08/07 12:42 PM Share Posted 04/08/07 12:42 PM mine hangs down a bit.. but I think I broke some clips when iv knocked the underside of the lip on those stupid low concrete "guides" at shopping centres.Is it the clips?same but at a race track called "mallala" the bumper looks fine but if you look close its all cracked and sags the slightest bit and makes a horried noise when idling, silly sand dunesBut I think the bumper rattle started before this crash any ideas ? Link to comment Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 1m 10d Location: Melbourne Posted 30/03/09 01:15 PM Share Posted 30/03/09 01:15 PM mine was the same I just put two self tappers on the upper section in the lower mouth of the bumper hold it in position n drill some holes then just scew into place looks great n isnt going anywherep.s I had no gap at wheel end but as it went towards the headlight it got huge lol was really annoying will take pics tomorow n post upbillthat's what mine is doing. Link to comment Share on other sites More sharing options...
