our06t Mmmmm......BOOST Member 3,135 Member For: 17y 10m 5d Gender: Male Location: central coast Posted 13/07/07 08:43 AM Share Posted 13/07/07 08:43 AM hey all think I might have a dodgey actuator what happens if connect a direct line between the turbo and actuator bypassing the solinoidI have a cv tune monza cooler siemens injecters and under load at lower revs I'm sure I can hear the actuator surging and realesing small amounts of boost and the car slightly looses power each time I hear it ,it seems ok once the load comes off the car and revs build upcheers Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 11m 9d Gender: Male Location: nsw Posted 13/07/07 08:53 AM Share Posted 13/07/07 08:53 AM if you bypass the control solonoid with a hose it will make 4.5 psi.dont block it off. it will boost hard and probly blow.if you have a problem with it call con he may be able to fix u up.its hard to hear the wgate opening but it may be the case the tune is blowing off a bit of boost down low so itss not so hard on the motor. as I said talk to your tuner he will sort u out. Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 10m 5d Gender: Male Location: central coast Posted 13/07/07 09:10 AM Author Share Posted 13/07/07 09:10 AM yeh jeff an con are more than happy to take a look at it it's just I live about 1 1/2 hours away so just tryin to have some idea what the prob is before I head back down there Link to comment Share on other sites More sharing options...
KW CONNER Member 52 Member For: 17y 10m 3d Location: Cessnock Posted 14/07/07 10:28 AM Share Posted 14/07/07 10:28 AM My one was doing the same thing , Autotech found that the bov spring was too soft and was opening and shutting on light throttle .But if you hear a spring noise , it could be actuator . Link to comment Share on other sites More sharing options...
