V6 For Falcon
f-wolf
  • Member For: 21y 2m 17d
  newl said:
Struggling to find full time employment? Come on. If people are having trouble getting jobs, they're not looking. There's more work out there now than anyone can shake a stick at.
At what pay? , Don`t tell me you work in the mining industry. We have had heaps of people go interstate for that not all the states have jobs like that on offer.And not everybody wants to move either.
  • Replies 123
Guest newl
  • Guests
No, I do not work in the mining industry. I'm currently a Software Engineer. If I wasn't though, I could quite easily find another job in any industry that would pay the bills. Doing something would with oneself is better than doing nothing and collecting the dole no matter what it is.
  • Member For: 21y 21d
(The Duratec is a range of four, six and twelve-cylinder gasoline engines used in Ford cars.)
Heres and idea ford, a twin turbo V12 with 800+hp, :spoton: ohh yeah.
Buy seriously these motors are excelent for there purpose, and are better then what we have now for normal driving around but they are,
correct me if im wrong, like chip packets.
They are unrebuildable (you can not bore/hone and fit over sized pistions or press in and out sleves, so there goes any chance of making decent power upgrades with engine rebuilds like lots of people have today,
they aslo wont be much stronger then they have to be, because strenght equals weight and weight increases effort, so even a 50kw upgrade could be the limit.
This is like toyota motors (most jap motors today) as if they have major dramas, they carnt be rebuilt, all you can do is pull out the motor and bin it.
Though at the end of the day you cannot expect Ford to build cars to be modified, and they have strict rules to follow if they want to sell cars.
But can someone explain to me why Expensive Daewoo can sell 6 liter V8's and pass the rules and we carnt with our 6?
Dont tell me that the 6 liter produces less emmissions and is more fuel efficent.
All I hope is there is always a performance version that increases in performance every year,
or otherwise our T's and phoons will become the next "XY GTHO Phase 3 falcons" and will go up in value in the years to come.
  • FG Falcon fan!
  • Member For: 21y 9m
I can only presume its not cost efficient to make the 4.0L 6 block out of alloy if you can get an existing engine out of the Ford lineup overseas.
Shame though. Just give us an alloy block, maybe take the capacity down to 3.8L
Make the Falcon a smidge smaller...
bloody V6s...
  • Member For: 17y 11m 12d
Cyclone V6: in the eye of a Ford storm
18/07/07
A Duratec V6 engine is the likely contender for the Ford Falcon if the Geelong-made inline six is killed off, writes IAN PORTER.
Ford Motor Company's 3.5-litre V6 - known as the Duratec 35 and 'Cyclone' - is favourite to replace the Australian-built in-line six-cylinder engine by 2010.
The engine most likely to slip into the Falcon's engine bay in 2010 will be the Duratec 35 - also known as Cyclone - which went into production in the US late last year.
Of the several available engine options in the Ford world, the Duratec V6 is believed to best fit the Falcon's workload needs should the decision be made to kill off the inline six-cylinder engine that has been made at Ford's Geelong plant for more than 40 years.
Like GM Holden's High Feature V6, the Cyclone comes in a range of sizes and specifications and has, perhaps surprisingly, found its way onto a list of the top 10 engines in 2007.
It is already in use in Lincoln's medium-sized all-wheel-drive MKZ saloon and is set to be rolled out across Ford's US range.
Lovers of the local XR6 Turbo and the FPV Typhoon should not be concerned about the possible death of the Geelong-made inline six, which has made the six-cylinder performance Falcons V8-killers of the first order.
The Cyclone has already been developed in twin-turbo form, with direct injection as well, laying the groundwork for another respectable performance car.
The main attraction the Cyclone has over the current I6 motor is its aluminium engine block, which makes it easier to achieve the Euro IV emissions standards that will be introduced for locally made cars in July 2010. Imported cars will have to meet Euro IV standards from July next year.
While the current motor has all the necessary hardware in its cylinder heads - twin overhead cams, four valves a cylinder and variable valve timing - to be competitive, the cast-iron engine block takes that bit longer to reach operating temperature.
Any engine runs below its optimum while warming up and that extra time it takes for the Barra engine to warm up is believed to make the difference in emissions tests.
The aluminium block is also lighter and smaller, enhancing economy and emissions while offering the usual V6 packaging benefits of shorter length and the possibility of more space inside - or the same space in a smaller package.
Although Ford casts aluminium cylinder heads at Geelong, it seems the company is unwilling to extend that competence to cylinder blocks. Perhaps head office has ruled out the prospects of investing any money in an inline engine - even though the I6 layout appears to be making a comeback at Land Rover and Holden/Daewoo.
The Cyclone has 24 valves, four camshafts, variable intake timing, coil-on-plug ignition and multi-port fuel injection. In 3.5-litre form, it delivers economy of 8.7 L/100 km in the Lincoln MKZ , which weighs 1570 kilograms in front-wheel-drive form (a Falcon weighs 1690 kilograms).It produces 196 kW at 6250 rpm, compared with the inline six's 190 kW at 5250 rpm.
Where they differ is on peak torque. The Barra engine, renowned for its low-speed pulling power, produces 383 Nm from 2500 rpm, while the Cyclone produces 339 Nm at a much later 4500 rpm.
The Cyclone was listed by the US automotive research group Ward's among the 10 best engines available in the US in 2007. The list included the 2.0-litre FSI turbo from Audi, two straight-sixes from BMW as well as a perennial winner of awards, Nissan's 3.5-litre VQ series V6 unit.
  • Sucker
  • Moderating Team
  • Member For: 20y 11m 12d
Nothing to worry about? :oohwoah:
That's what makes the I6 so farkin good :bowdown:
  tab said:
Nothing to worry about? :blink:
That's what makes the I6 so farkin good :stirthepot:
And this from Ford US,
The 360Hp Direct Injected Twin Turbo V6 based on the D35 was already approved for production.
that's about 237 KW !! BIG DEAL!
And this is what the press in the US of A calls the V6 3.5.
Ford's latest Way Forward cost-cutting tactic, according to Automotive News is to starve the new Lincoln flagship of a V8 engine -- a feature many consider crucial to meet competitors in the luxury market. Instead, the upcoming MKS sedan will get only Ford's new, fits-in-everything 3.5-liter V6 (Duratec 35, or Cyclone), which produces in the neighborhood of 240 265 hp currently -- but Ford plans to "differentiate" the engine in the MKS, likely by maxing out its power potential (twin-turbo anyone?). AN says executives shelved a plan to use the Yamaha-sourced V8 from Volvo's XC90 for eight-pot goodness in several models. Ford's definitely lacking in small V8s for such applications; the question is, can they convince buyers not to care?
Edited by f-wolf
  • Member For: 18y 6m 7d
so potentially heavier car, less low down torque, even ralph wiggan knows that doesn't make sense. combine with twinturbo, gonna be some lag....
And this,
More on Ford's New, Workhorse V6
Ford released a bunch of engine-geek info on the new 3.5-liter V6 that'll power a goodly portion of its new cars, particularly its crossovers like the Ford Edge and Lincoln Aviator set to appear at the Detroit Auto Show in January. Ford officials say the high-revving all-aluminum six, which will wring 250hp and 240 lb-ft of torque out of its dual-overhead cam valvetrain, will power one in five Ford vehicles by the end of the decade. Paired with a new six-speed automatic, it'll make its way into cars like the the Ford Five Hundred, Mercury Montego and new Lincoln sedans on the docket, and will play a pivotal role in future Ford hybrids.
