MUZ580 Member 448 Member For: 18y 9m 8d Gender: Male Location: Manly - Sydney Posted 13/07/07 01:14 AM Author Share Posted 13/07/07 01:14 AM Too easy Kev, thanks for the advice. I thought that was the way to go. Link to comment Share on other sites More sharing options...
brady Member 2 Member For: 17y 9m 14d Posted 01/08/07 12:49 PM Share Posted 01/08/07 12:49 PM Sorry to dig up an old thread but... I am currently doing custom 3" to intercooler on mine and want to know... if I put a 3/8 barbed fitting into the I/c pipe b4 the t/b, and run a 3/8 hose from this to the boost/map sensor...(am I able to mount the sensor somewhere else so I dont have to extend the wires? )Cheers Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 9m 12d Gender: Male Location: nsw Posted 01/08/07 09:45 PM Share Posted 01/08/07 09:45 PM yes you can but dont go too far. Link to comment Share on other sites More sharing options...
plazmaman Member 43 Member For: 18y 4m 7d Posted 07/08/07 12:15 AM Share Posted 07/08/07 12:15 AM Sorry to dig up an old thread but... I am currently doing custom 3" to intercooler on mine and want to know... if I put a 3/8 barbed fitting into the I/c pipe b4 the t/b, and run a 3/8 hose from this to the boost/map sensor...(am I able to mount the sensor somewhere else so I dont have to extend the wires? )Cheers If you are in Sydney mate , you can come round and purchase one of our aluminium sensor bosses and we can weld it to your piping where evr you want . ( mark with texter and must pull off vehicle and alloy to be clean ) . Approx $30 - $40 depending on application . Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 2m 18d Gender: Male Location: Miranda Posted 05/01/10 09:54 AM Share Posted 05/01/10 09:54 AM Hey GuysWhat are the effects of having the cold side boost/map sensor in the following 2 positionsProcess west 3/8 hose running about 1000mm across trhe engine bay to the sensorPlazman sensor fixed directly to the cold side piping whith extended wiresMy concern is that the process west version will either give a in accurate reading, overboost, or delaywhat are the advantages of each?ThanksMatt Link to comment Share on other sites More sharing options...
Process West Member 248 Member For: 18y 7m 3d Gender: Male Location: Wollongong NSW Posted 05/01/10 10:34 AM Share Posted 05/01/10 10:34 AM MattDont stress...the hose will pressurise instantly...try blocking one end and blowing in the other..you will see what I mean.The hose will come up in pressure at the same rate as your intercooler piping....pressure is constant everywhere.Kev Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 2m 18d Gender: Male Location: Miranda Posted 05/01/10 10:41 AM Share Posted 05/01/10 10:41 AM Hey KevI can understand that in a fluid system but as air can pressurise I dont see how it is the same? like blowing air through a thin straw and through a maccas straw, this is where my concern lays in the delayCheers Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 2m 18d Gender: Male Location: Miranda Posted 07/01/10 11:28 PM Share Posted 07/01/10 11:28 PM I have been told by pulse that there is another pressure sensor in the throttle body so I dont need to worry too much.im happy with that answer Link to comment Share on other sites More sharing options...
Process West Member 248 Member For: 18y 7m 3d Gender: Male Location: Wollongong NSW Posted 07/01/10 11:59 PM Share Posted 07/01/10 11:59 PM Correct..the one in the inlet manifold is the MAP sensor Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 2m 18d Gender: Male Location: Miranda Posted 08/01/10 07:38 AM Share Posted 08/01/10 07:38 AM There was another post in this thread that suggest the boost and map sensor were both in the relocated sensor, this is why I was concerned Link to comment Share on other sites More sharing options...
