  • Into the laaaake
  • Member For: 17y 11m 10d
Its simple as on the utes. But you do need a 15mm spanner for the drain bolt, and a 1 1/8in spanner for the fill bolt, (its a big bugger).
I just filled it till it just spilt out the filler hole. It took 1.7L.
Use this stuff.
Its for the XR range.
Filler and drain holes.
You can actually pour it in straight out of the bottle with the pumpkin rear end.
Edited by Adam
https://www.fordxr6turbo.com/forum/topic/36540-changing-ute-diff-oil/
  • Replies 44
  • Created
  • Last Reply
Top Posters In This Topic
  • 4 weeks later...
  • <put funny sh*t here>
  • Member For: 18y 6m 16d
do you just fill it till it starts to overflow from the fill hole up the top?
Sedan would be the same process im guessing, pretty straight forward
Edited by XF Falcon
  • Into the laaaake
Yeah I just filled it up till it over flowed. It took 1.7L I think the handbook says its capacity was 1.65?
Sedan has IRS, this is live axle so there will be differences.
  • 1 month later...
  • They see me rolllin n hatin...
  • Member For: 19y 4d
Thanks for the pics and details, even I could do that who doesn't know crap about mechanical stuff :spoton:. Oil was so black/navyish. 36000km on the clock.
