gu4800 Member 156 Member For: 17y 8m 17d Location: Brisbane Posted 08/07/07 04:08 AM Share Posted 08/07/07 04:08 AM So if it is the Fuel pump, are these easy to fit. Or am I best letting my tuner do it. I found this one on Ebay --> HERENot easy but not hard - you just have to have the right gear handy. Some points:1) Avoid soldering or crimping the wires to join the Ford loom into the new Walbro plug. Simply cut the existing wires as close as possible to the old Ford plug (the end that plugs inot the pump), remove the wires from the new Walbro loom and put new connectors onto the Ford harness. Simply insert the new connectors into the Walbro plug. The Walbro connectros are standard Narva connectors. Put simply - change the plug on the existing Ford loom to Ford one end and Walbro the other! 2) You MUST MUST MUST MUST have Gates submersible fuel hose ($30 trade price from Repco) at the ready. A little bit of trial and error witht he correct length of fuel hose and that's about it.If you want more of a technical write up let me know.One last thing - sedan = easy, ute = hard (apparently you have to drop the tank in the ute - sedan is under back seat).Dan Link to comment Share on other sites More sharing options...
NATHOON Donating Members 197 Member For: 18y 5m 8d Gender: Male Location: Sydney Posted 08/07/07 07:58 AM Share Posted 08/07/07 07:58 AM Drop the exhaust undo the diff undo the tail shaft slide the diff back and slide the tank out 2 hou job with a hoist Link to comment Share on other sites More sharing options...
F6 RAPID Formerly Turbo6 Donating Members 2,332 Member For: 21y 11m 19d Location: North Brisbane Posted 08/07/07 09:31 AM Share Posted 08/07/07 09:31 AM Get your coils tested. Three of mine were stuffed at 17,000kms. It will display those symptoms - especially under load. Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 20d Gender: Male Location: North of The Bridge Posted 08/07/07 01:20 PM Share Posted 08/07/07 01:20 PM Is there any chance that it could be a dodgy cat?nope, no chance of it being the cat F6 if it were the coils would it feel somewhat like a cylinder misfire, hence the change in exhaust note? Link to comment Share on other sites More sharing options...
FPVWEPN Member 12 Member For: 17y 8m 4d Posted 09/07/07 12:44 AM Share Posted 09/07/07 12:44 AM I have similar problems but only when it is cold economy is also around 250kms to a tank and is sh*tting me aswell. I have similar mods to you 968's cooler, x-force, springs, and walbro pump aswell also my thermos wont turn off!!!!!! How do you test the coils? Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 3m 24d Gender: Male Location: Townsville Posted 11/07/07 07:28 AM Share Posted 11/07/07 07:28 AM Get your coils tested. Three of mine were stuffed at 17,000kms. It will display those symptoms - especially under load.Will the ecu throw fault codes for this as my Supercharged XR8 ute is now playing up again and not sure what it is?I thought it was voltage clamps set wrong with the RDP Computer but I dont think so now and it only cut out at 4000rpm in 3rd gear not in 1st or 2nd!The only fault codes are o2 sensors being rich and this has never caused it to act up before? Link to comment Share on other sites More sharing options...
Hazey Member 234 Member For: 21y 4m 21d Posted 18/07/07 01:33 AM Author Share Posted 18/07/07 01:33 AM (edited) Okay just an update on this problem. The car has been running fine for 3/4 of a tank. And the symptoms I explained above started coming back approching 1/4 tank left.so is this a fuel pump symptom? I'm just confused as to why its started now and why it only happens when fuel is low.I can remember driving the car on many ocassions till empty with no problem?I am waiting for my Walbro to arrive. just not sure if I'm confident to fit it. without any side affects after Edited 18/07/07 01:34 AM by Hazey Link to comment Share on other sites More sharing options...
Hazey Member 234 Member For: 21y 4m 21d Posted 20/07/07 07:01 AM Author Share Posted 20/07/07 07:01 AM Okay just an update on this problem. The car has been running fine for 3/4 of a tank. And the symptoms I explained above started coming back approching 1/4 tank left.so is this a fuel pump symptom? I'm just confused as to why its started now and why it only happens when fuel is low.I can remember driving the car on many ocassions till empty with no problem?I am waiting for my Walbro to arrive. just not sure if I'm confident to fit it. without any side affects afterOkay ignore the above. Filled the tank up and it is still doing it. I am now also getting a short quick whine noise in the lower gears. E.g when taking off and from 2500-4000?? It sounds like it is coming from behind me when drivingAny suggestions on this problem. Link to comment Share on other sites More sharing options...
ALF05T Member 453 Member For: 17y 11m 13d Gender: Male Location: Sydney Posted 20/07/07 08:34 PM Share Posted 20/07/07 08:34 PM I have a Walbro fuel pump and under hard acceleration it whines for a little whilecan be heard from the rear. Link to comment Share on other sites More sharing options...
