Hazey Member 234 Member For: 21y 5m 9d Posted 06/07/07 12:07 AM Share Posted 06/07/07 12:07 AM Hello,My Edited T is experiecing a strange problem. The only thing that has changed is the cold weather.It can happen at light throttle/low revs and continue all the way through the rev range. I can be cruising at 60km with the lightest throttle and it will occure. It happens in any gear. After car has been warmed up it will still occure.The closest thing I can compare it to is the feeling you get when traction control comes on and it cuts power to the engine. Happens if TC is off or on and light does not come on when it happensIt also can happen when the car is stationary and I just rev the car. One thing maybe worth noting is you get kind of a reverb/change in exhaust note when it happens.I have changed the boost solenoid thinking it was this. I took it back to my tuner last week who said it was torque parametres and had to play with these.I dont understand how this could of just come on, It does it on all my tunes. My tuner said he fixed it and car was going ok for couple days but has started doing it again. (To be honest I dont think he actually experienced it when the car was there.)I will take it back to the tuner and see what they say.My Mods:968 injectorsProcess West intercoolerValve Springs290rwkw ( was running 276rwkw when problem 1st started and Tuner got some more power for me)Any suggestions or anyone had this problem before?? Link to comment Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 8m 11d Gender: Male Posted 06/07/07 01:49 AM Share Posted 06/07/07 01:49 AM Id say fuel pump mine was doing the same thing sort of, mine was only doing it in high revs. But when it did happen it was making that sound like the traction was on like you said and the exhaust note to. My first tuner also said the car was fine but it keeped doing it untile I made them do the pump Link to comment Share on other sites More sharing options...
Hazey Member 234 Member For: 21y 5m 9d Posted 06/07/07 04:16 AM Author Share Posted 06/07/07 04:16 AM Now that you mention fuel pump.. I can remember prior to this problem that after the car was driven for a while/hard, there would be a strong smell of fuel. ie sitting at the lights with window open. This was more noticiable in the hotter weather. Not sure if its normal or related to this current problem. Also my fuel econemy is absolutly crap. I used to get 330/300km per tank and now getting 250 Link to comment Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 8m 11d Gender: Male Posted 06/07/07 04:23 AM Share Posted 06/07/07 04:23 AM that's not normal, I would say its the pump. Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 1m 8d Gender: Male Location: North of The Bridge Posted 06/07/07 05:15 AM Share Posted 06/07/07 05:15 AM is it more common in the first 10 minutes of driving then seams to disapear when the car reaches normal operating temp? Link to comment Share on other sites More sharing options...
Hazey Member 234 Member For: 21y 5m 9d Posted 06/07/07 06:20 AM Author Share Posted 06/07/07 06:20 AM It will still do it when the car is warm. And it wont do it straight away on a cold start (I mean it has, but most times I can drive about 5 min without it doing it, and them it will start) Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 1m 8d Gender: Male Location: North of The Bridge Posted 07/07/07 06:11 AM Share Posted 07/07/07 06:11 AM yep, sounds about the same as mine... was supposed to get it looked at last week, but didnt. If you get it sorted let me know what it is, I think mine might be the pump aswell but am not 100% Link to comment Share on other sites More sharing options...
Hazey Member 234 Member For: 21y 5m 9d Posted 08/07/07 02:44 AM Author Share Posted 08/07/07 02:44 AM So if it is the Fuel pump, are these easy to fit. Or am I best letting my tuner do it. I found this one on Ebay --> HERE Link to comment Share on other sites More sharing options...
Desert_phantom Member 141 Member For: 18y 3m 28d Gender: Male Location: NT Posted 08/07/07 03:38 AM Share Posted 08/07/07 03:38 AM Is there any chance that it could be a dodgy cat? Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 11m 1d Gender: Male Location: SYDNEY Posted 08/07/07 04:01 AM Share Posted 08/07/07 04:01 AM Link to comment Share on other sites More sharing options...
