urslow Resident golf buggy drift champion Donating Members 815 Member For: 19y 6m 20d Location: Lismore NSW Posted 17/07/07 11:54 AM Share Posted 17/07/07 11:54 AM I hid mine sounds good and cops cant see it - Turbosmart dual port kompact Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-555851 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 15d Gender: Male Location: nsw Posted 18/07/07 12:27 AM Share Posted 18/07/07 12:27 AM it looks right.what is connected to the top of the bov, you should use the stock bov vacume line and extend it.you may not have vacume hooked up to the top ov the bov. Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-555987 Share on other sites More sharing options...
Toxic Beast Member 514 Member For: 18y 8m 15d Gender: Male Posted 18/07/07 11:12 AM Author Share Posted 18/07/07 11:12 AM BFHOON said: it looks right.what is connected to the top of the bov, you should use the stock bov vacume line and extend it.you may not have vacume hooked up to the top ov the bov.Hey Bf Hoon, yes the vacume line hooked into the side of it. which is where its meant to go. So having such a long adaptor connecting the Bov wouldn't cause it?When I rev my car on the spot, I get the PSSH and no flutter. but when I drive off, I get the flutter.and I shouldn't get this as its an atmospherical bov. would this be due to stock boost?thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-556288 Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 1m 29d Gender: Male Location: Melbourne,S.E Posted 18/07/07 11:20 AM Share Posted 18/07/07 11:20 AM Could be that under higher pressure of boost the spring inside the BOV gets soft and doesnt react qick enough to make the PSHH noise.mabye that why when you rev the car on the spot is only a small amount o boost going threw and you get the pshh noise.I dunno just a thought. Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-556290 Share on other sites More sharing options...
Toxic Beast Member 514 Member For: 18y 8m 15d Gender: Male Posted 21/07/07 05:03 AM Author Share Posted 21/07/07 05:03 AM I tried this bov on my mates xr6t whos running 10psi and just under 300 rw kw.this bov sounds exactly the same as it is on mine.as quiet as dropping a 5cent coin on the ground Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-557150 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 5d Gender: Male Posted 21/07/07 06:16 AM Share Posted 21/07/07 06:16 AM that's because its crap, that's why it was on a WRX Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-557163 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 15d Gender: Male Location: nsw Posted 21/07/07 07:26 AM Share Posted 21/07/07 07:26 AM if u want big noise mate u need a gfb mach 1.I have mine plumbed back but on open air it can be heard 2 blocks away on 15 psi. Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-557176 Share on other sites More sharing options...
Toxic Beast Member 514 Member For: 18y 8m 15d Gender: Male Posted 21/07/07 08:34 AM Author Share Posted 21/07/07 08:34 AM right michael. lol..I actually think the ebay seller sold me a dodgy bov cuz I put it on my mates wrx 2day and it just has a mild pssh which isnt the sounds its suppose 2 make..wats this gfb mach1 bf hoon?thanks Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-557192 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 5d Gender: Male Posted 21/07/07 08:53 AM Share Posted 21/07/07 08:53 AM Toxic Beast said: right michael. lol..lol I just thought id add my 2 cents..... ANDREW Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-557196 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 15d Gender: Male Location: nsw Posted 21/07/07 09:29 AM Share Posted 21/07/07 09:29 AM The Mach 1 and Plumback valves have now been combined into one affordable unit - the new Mach 1 kit comes complete with the parts required to make this valve vent to atmosphere for maximum noise, or plumb back for silent - and very importantly - LEGAL - operation.The loudest valve in the range, the Mach 1 will let people know you're coming! Featuring a single trumpet discharge outlet, this is a good replacement for factory valves and will help to reduce turbo lag and increase throttle response while blasting out a great WHOOOSH noise between gears. Flows enough air to support engines in the vicinity of 250kW.quote..gfb Link to comment https://www.fordxr6turbo.com/forum/topic/36388-how-do-i-fit-this-bov-on/page/2/#findComment-557204 Share on other sites More sharing options...
