  • Moar Powar Babeh
  • Member For: 19y 8m 27d
  EXRLNT said:
I dont know why but i have to disagree with u there fordnumber1.
My average speed is 32kms and i average around 460-480kms.......
:spoton: 38kms and 450 t0 500k's out of the tank in my ute......
  • Replies 45
Guest FatBAt
  • Guests
  ZAP_F6 said:
That is not entirely correct.
When I had a Edit with custom tune, I got between 2-4lt/100km better economy over the tank.
While the car would use more fuel when booting it, overall it was noticably better with economy.
Economy does not = slow in our cars.
Economy = properly tuned
ZAP I didn't say economy = slow. My wife drives our car mostly and after a week or so when I drive it the average has climbed to high 16's. I give it a few small squirts and drive (a little) harder than she and it drops to high 15's low 16's. That defies logic but that is just the way it is. My car before edit never saw the other side of 15 l/100klms. 13's mostly. Now it's 15's-16's (260rw) This could just be attributed to the fact that the car has 80000k on the clock. Who knows.
There is more to it than just a custom tune and Kw to determine fuel economy. What about climate, the type of oil you run, vehicle age, tyre (type, size and pressures), driving style and a million other variables that will change fuel economy. Where you live, traffic and enviroment. All impact on fuel economy. Custom tune might fix a few of these things but will it make an impactable difference to warrant Rapid spending $1000.
What I would suggest 1st is to change driving style (which is sorta hard to do)and increase tyre pressures to "say" 40psi. They cost nothing to start with.
As I said. Every car is different.
  • Formerly XR6NA
  • Member For: 19y 6m 20d
  hiddeous said:
:stirthepot: 38kms and 450 t0 500k's out of the tank in my ute......
Utes have a slightly bigger tank don't they?
  • Member For: 18y 9m 15d
Slow or fast driving does not mean better economy (that is a myth).
Smooth driving is the key.
Smooth, brisk acceleration up to your crusing speed uses less fuel than slowly accelerating the car up to speed. It's not until cruising speed is reached, that the car is at optimum efficiency.
Go too slow and you car is under load and not at peak mechanical efficency, that is why we all get much better economy when on longer trips (more time spent at crusing speeds).
My car is used mainly for to and from work (short 20k trips). That said, I'm pretty happy with my average consumption of the mid 13s, which is about 440 per tank (even with the odd squirt here and there). My average speed is about 43.
When I do longer trips though (even to the airport and back) I drop to under 10.
The fuel also helps a lot. I mainly run BP Ultimate, but if I can't get a 98 ron fuel, I've noticed that the economy gets knocked to hell.
  • Moar Powar Babeh
Yeah they do. Im not 100% what the difference. Im running 320rwkw and 4.11's in the diff so in pretty happy with the quality of the tune from Simon from Xtreme and the fuel consumption i get :tonguepoke:
  • loitering with intent
  • Member For: 21y 10m
  fordboy1981 said:
well my BA MKII turbo used to get 18.3L/100km for the time I owned it.
and the ute's even worse, 20.3L/100km!
Dave, you should sit back relax, enjoy the shrimp and let the economy look after itself :spoton:
  • Crusty aviator
  • Member For: 21y
Have used mine in Canberra throughout and the fuel consumption really hasn't changed, initially standard, APS Phase 1 then 2 followed by CObra Stage 1 then 2 and 15s around the city with the occasional fang and mid 9s on the highway.
I avoid the Boost 98 which certainly makes the consumptiom worse and the best fuel around here is Caltex Vortex 98.
Both Bugester and Galcon as good honest ACT citizens with quite different tunes and VERY different driving styles both look towards the same averages too.
Dingah
  • My engine bay is Bionic
  • Member For: 19y 3m
  rapidmkII said:
As above, we're only getting 340Kms to a full tank in a BA MKII Turbo.
any reason why??? and has it happened to others, car has no mods at all.
This topic now 4 pages long and I wont read it all, but your fuel consumption is way up there. City driving does kill it, but 400 per tank is more realistic and open road stuff 500k's easily. Even with flogging your car you should be doing much better.
Whats your average litres per 100 fuel consumption thing saying??
O.K. just read the entier topic. Custom tuning does help fuel economy. When I run around in my 8PSI tune I get more k's per tank than the standard Ford tune was ever getting me. About 50 k's actually and this includes plenty of floggings. And when I run the 10PSI tune it gives me the same economy as the factory tune, go figure.
And make sure your running the right fuel, 95/98 RON, not 91 in these cars. If your always filling up at the same servo, consider changing for a while and see if this helps. when it comes to fuel dont compromise and go to the cheapest independent you can find, just play it safe and get ripped off like the rest of us at the major servo's.
I.B.
Edited by Iconic Bionic
