hanra Into the laaaake Member 1,532 Member For: 17y 11m 5d Gender: Male Location: Nrth Qld Posted 30/06/07 08:39 AM Share Posted 30/06/07 08:39 AM So I just drove my new XR6T ute home from the Gold Coast to Cairns....1800klms and 21hrs worth of driving. Im going to do the oil/filter 2morrow and would like to know wat type of oil and weight is best to use. Its done 51,000 k's now. Also what weight diff oil should I use as I was intending on changing that while I was at it. At some stage in the next few weeks id like to change the auto trans fluid as well. Cheers. Brad. Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/ Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 5m 3d Location: nowhere in particular Posted 30/06/07 09:31 AM Share Posted 30/06/07 09:31 AM This link may help you. Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/#findComment-550152 Share on other sites More sharing options...
Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 19y 2m Gender: Male Location: Freeways Posted 30/06/07 11:44 AM Share Posted 30/06/07 11:44 AM Im not sure what model you are, BA/BF, but if your BF with a ZF auto, no need to do the fluids.And with you motor oil everyone is going to have there own opinons, just like with tyres, brakes, fuel and who to vote for at the next election. I'd keep it simple, with a well known brand name that is of course a full synthetic and how could you go wrong.Any mods, might steer you into a direction as well. Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/#findComment-550262 Share on other sites More sharing options...
Jonno Member 79 Member For: 18y 9m 11d Posted 02/07/07 06:38 AM Share Posted 02/07/07 06:38 AM hanra said: So I just drove my new XR6T ute home from the Gold Coast to Cairns....1800klms and 21hrs worth of driving. Im going to do the oil/filter 2morrow and would like to know wat type of oil and weight is best to use. Its done 51,000 k's now. Also what weight diff oil should I use as I was intending on changing that while I was at it. At some stage in the next few weeks id like to change the auto trans fluid as well. Cheers. Brad.Mate, if its a BF I say. Castrol Edge 0W40. Do not be tempted by other oils, including Edge 10W60. It is better to have a lower viscosity oil when the engine is cold (ie 0W is better than 10W).When hot, the 40 weight is fine.In my BF XR6T I use the edge 0W40 and find that there is seemingly no cranking resistance on start up.I had the oil chanked at 1,500kms, and now have 12,000kms odd, and have had no problems, and used no oil.I suggest that to get most benefit from the Castrol, that you run a flushing oil through the engine first. Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/#findComment-550850 Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 4m 4d Posted 02/07/07 07:45 AM Share Posted 02/07/07 07:45 AM (edited) Jonno said: Mate, if its a BF I say. Castrol Edge 0W40. Do not be tempted by other oils, including Edge 10W60. It is better to have a lower viscosity oil when the engine is cold (ie 0W is better than 10W).When hot, the 40 weight is fine.In my BF XR6T I use the edge 0W40 and find that there is seemingly no cranking resistance on start up.I had the oil chanked at 1,500kms, and now have 12,000kms odd, and have had no problems, and used no oil.I suggest that to get most benefit from the Castrol, that you run a flushing oil through the engine first.It may pay to warm the car with the low viscosity oils before loading up the engine.Just remember that whilst a zero weight oil flows well at start up, there is a reason why the viscosity is designed to go up at operating temperature. Regards,aa Edited 02/07/07 07:48 AM by aiboart Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/#findComment-550878 Share on other sites More sharing options...
jasper361 Member 407 Member For: 20y 4m 3d Location: Brissy Norf siide Posted 02/07/07 09:34 AM Share Posted 02/07/07 09:34 AM Mobile1 5w50, also good for removing grease and red wine stains Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/#findComment-550929 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 11m 5d Gender: Male Location: Nrth Qld Posted 02/07/07 09:26 PM Author Share Posted 02/07/07 09:26 PM I just used Penzoil 15-40 mineral based oil. that's what Ford Svc Centre recommends. Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/#findComment-551100 Share on other sites More sharing options...
shitbmxrider Donating Members 420 Member For: 19y 1m 18d Gender: Male Location: Mill Park, Victoria Posted 03/07/07 01:05 PM Share Posted 03/07/07 01:05 PM hanra said: I just used Penzoil 15-40 mineral based oil. that's what Ford Svc Centre recommends.What about Castrol TWS Motorsport? its a 10w-60, and is the only approved oil for the m-series bmw's(I can get it thru work) Link to comment https://www.fordxr6turbo.com/forum/topic/36242-wat-oil-for-xr6t/#findComment-551467 Share on other sites More sharing options...
