aiboart Member 665 Member For: 20y 8d Posted 28/06/07 02:20 PM Share Posted 28/06/07 02:20 PM My auto BAT's cruise control is malfunctioning. The car is stock.The 'CRUISE' icon goes out after random periods of time following an engine start. Period ranges from 1 minute to 20 minutes.The 'CRUISE' control icon (and cruise control function) will not activate unless the engine is first stopped and then restarted.The problem manifest immediately after a warranty replacement of the throttle position sensor. There had never been any problems with the cruise system prior to this.The dealership is most helpful but cannot find the solutions atm. They did repair a faulty brake light and thought that they had solved the problem at that stage.Subsequent dealer investigations have found system codes that suggest a wiring issue. The Forum search function does not yield any examples of this exact problem.I did ask the dealership to backtrack to the throttle position sensor repair to check for loose connectors and pinched wires.Any ideas anyone?Regards,aa Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 8m 29d Gender: Male Location: ACT Posted 28/06/07 11:02 PM Share Posted 28/06/07 11:02 PM Cruise control is controlled from and by a lot of switches and senders including switches on the clutch and brake pedal.On my wifes Toyota some years back I found the Brake Switch to be RS . The cruise control used to drop out @ times. Link to comment Share on other sites More sharing options...
veczar Gold Platinum Member Member 1,081 Member For: 20y 6m 28d Gender: Male Location: Victoria Posted 09/07/07 04:35 AM Share Posted 09/07/07 04:35 AM It is not 'going off' cruise is it, not asif you tap brake? The whole system is switching off as if you click the off button? Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 29d Gender: Male Location: Brisbane Posted 09/07/07 04:57 AM Share Posted 09/07/07 04:57 AM I think that's what he's saying. I would suggest it's something with the TPS, as if the cruise control detects any problems it will just simply shut down.What are the dealers doing now - or is it sitting in the 'to hard basket'? Link to comment Share on other sites More sharing options...
Dave Member 7 Member For: 17y 7m 12d Gender: Male Posted 11/07/07 01:15 PM Share Posted 11/07/07 01:15 PM The 'CRUISE' icon goes out after random periods of time following an engine start. Period ranges from 1 minute to 20 minutes.The 'CRUISE' control icon (and cruise control function) will not activate unless the engine is first stopped and then restarted.I had the same problem on my BF - turned out to be the blue plastic cap on the back of the sensor would half-pop off all by itself. Had me guessing though. No warnings or anything - just no cruise. Link to comment Share on other sites More sharing options...
kilmo Donating Members 122 Member For: 17y 6m 22d Gender: Male Location: Perth, WA Posted 03/08/07 03:13 PM Share Posted 03/08/07 03:13 PM I won't start a new thread instead I'll just ask here.....my Cruise Control is playing up too.Problem: Cruise Control can be turned on using the side paddle to get the "CRUISE" indicator on the dash, but pressing RES/CRUISE, SET + and SET - buttons does not set the Cruise Control.... Any ideas ?????Kilmo Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m 28d Gender: Male Location: Victoria Posted 04/08/07 02:23 AM Share Posted 04/08/07 02:23 AM Check your brake light fuse. Link to comment Share on other sites More sharing options...
kilmo Donating Members 122 Member For: 17y 6m 22d Gender: Male Location: Perth, WA Posted 04/08/07 08:03 AM Share Posted 04/08/07 08:03 AM Fuses are all good......it's weird Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m 28d Gender: Male Location: Victoria Posted 04/08/07 08:38 AM Share Posted 04/08/07 08:38 AM The fuse is good but are you getting power on both sides of the fuse?Maybe you've dislodged a wire when wiring the gauges up to the phone connector. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 11m 9d Gender: Male Location: Sydney Posted 04/08/07 09:45 AM Share Posted 04/08/07 09:45 AM Did you replace the brake lights with LED's ?If so that is the problem. Link to comment Share on other sites More sharing options...
