  • The Bionic Man - half man-half titanium
  • Member For: 22y 2m 15d
I've gone the other way.
I've just ordered a set of 15" x 7" Police Airflow steel rims (Chrysler Police Pack wheels) for the Dodge (I already have the dog dish hubcaps) and I tracked down a set of brand new 225/70/15 tyres with a thin white stripe around the sidewall.
For all the low profile stuff, the larger you go with a rim, the larger a rolling diameter for a tyre and slower you are for a standing start acceleration!
  • Replies 47
Posted Images
  • Member For: 21y 10m 18d
As long as you lower the profile every inch that you increase the rim size therefore keeping the same rolling diameter all is good. I've got 18"x8" AMG wheels with Bridgestone SO3 Pole position rubber. The SO3's are the best tyre I've ever driven on and I've had Falken, Goodyear F1, Yokohama and Marshalls.
  • Moderating Team
  • Member For: 22y 4m 24d
  saleen1 said:
They look awesome! But lower that car boy!!!!!!!!!
that's strange! ive got 19's on my bus and my car sits WAY lower than yours tazz! And mine isnt lowered!
Are you sure they took out the red spring spacers at your dealership when you picked it up?
It shouldn't really relate to the Falcon because the largest rims and tyres you can buy at the moment are probably 19" or 20", however when you loook at increasing the diameter of the wheel, have a look at the tyre placard of the car.
This placard is generally inside the glovebox or on the door frame. They will give tyre pressures for the range of tyres fitted to the vehicle. If the largest factory wheel is 18" then you can go a Plus 1 fitment, which is a 19" wheel.
If you put on a wheel which is more than 25mm increase in the rolling diameter, then the wheel/tyre combo will have to be submitted to an engineer who can certify that in his opinion the wheel/tyre combo is safe for the car.
This also applies to offset and width of a rim.
Generally this is something the Fast Four and Bodykit set don't realise, especially when they run around on 18" rims on their Mitslugbishi Mirage or their Hi Undies Excel. The wheel set is illegal because of the massive increase in rolling diameter which is contrary to the ADR which the car was complianced under.
  • Great rack
  • Member For: 22y 2m 29d
While we're on the subject Plonky, whats the latest Reg's in reguard to ground clearance. Is it still around 5" or has that finally been amended?
Your thoughts please..................
