  • Uncle Bulgaria was gender challenged
  • Member For: 21y 11d
  Ninka said:
This is not specific to the phoon, but ALL BF's have independently variable VCT's and ALL BA model car have not (they vary exhaust and inlet side at the same time)
Interesting, heard about iVCT a long time ago when BF first came out and nothing since, memories can be dangerous :)
Any idea if there are actual hardware differences in the head or is it just enabled in the tune?
Edited by PepeLePew
  • Replies 22
  • Yaris member
  • Member For: 18y 10m 9d
  DORKO said:
So if I got a BFII can I get a F6 tune in my XR6t?
Dorko
I guess u could.. but they would still void your warranty so you might as well get a custom tune :spoton:
  • Member For: 18y 1m 19d
HAHAHHA. So what is the Difference from a XR to F6? Just the look and tune?
Dorko
  • Member For: 19y 1m 6d
lets see
phoon has brakes
wheels
bodykit
guages
street cred
did I miss anything.
im kicking myself now 5k more would have me a phoon.
Edited by BFHOON
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 18y 11m 26d
what about BA typhoons do they have the stroger bottom end?
And would it be worth putting a phoon bottom end in a BA for power reliability?
E.g. running more boost?
Cheers
Michael.
I would say yes and no, go an after market bottom end if you are going to do it do it properly.
I had the decision to put on more boltons and still be limited by the conrods or get a bottom end installed and see what I get with my existing boltons plus fuel pump and actuator/wgate housing mods.
im looking at 400 or so rwkw safe now instead of 350 not so safe.
Edited by BFHOON
  • Member For: 22y 4d
Dorko
The XR doesn't have the bigger intercooler or dual airbox, so the tune might not suit.
  • Toughest BA Turbo
  • Member For: 22y 4m 6d
With regard to the BA the F6 has the independently variable VCT capability, but not the XR6T.
Nizpro put a BA F6 ecu into my BA XR6T, and then used the Edit software to independently vary the exhaust and inlet cams.
All worked well except the oil light stayed on permanently.
Brian
  • Member For: 22y 4m 7d
Brian, I'm pretty sure all ECU's for the turbocharged I6 engines are the same I.e. BA XR6T/Phoon the same BF XR6T/phoon the same, so not sure how Nizpro did it.
My understanding is that for the BF's the ECU is significantly more powerful, which is why it is able to do this with the many thousand of calculations required for the correct settings.
Maybe the BA ECU is able to perform a more basic version of the VCT adjustments.
Oh and the oil light stays on, as the F6 tune expects a pressure transducer signal (as used for the gauge as well) instead of the XR6T's pressure switch.
I had this issue when I converted my car to a BF F6 specification in conjubction with fitting the ZF transmission - $250 later for an F6 oil transducer :w00t2: .
