byi Donating Members 159 Member For: 19y 8m 12d Posted 25/06/07 05:00 AM Share Posted 25/06/07 05:00 AM Can anyone please offer some insight as to where the F6 boost gauge is plumbed into? I have read a few topics discussing plumbing the boost sender into the blow off valve however I have been advised that this may not produce the most accurate readings. Does anyone know of another location along the line where I could install the sender?Cheers, Link to comment https://www.fordxr6turbo.com/forum/topic/36094-boost-gauge-plumbing/ Share on other sites More sharing options...
YellowTurbo Member 163 Member For: 18y 7m 13d Gender: Male Location: Darwin Posted 30/06/07 07:57 AM Share Posted 30/06/07 07:57 AM I have a mate who is the service manager at City Ford in Melbourne and he said that it's a whole different wiring loom. So hooking up F6 gaugues can't be done. Sorry Link to comment https://www.fordxr6turbo.com/forum/topic/36094-boost-gauge-plumbing/#findComment-550120 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 5d Gender: Male Location: central coast Posted 13/07/07 03:11 AM Share Posted 13/07/07 03:11 AM I have a mate who is the service manager at City Ford in Melbourne and he said that it's a whole different wiring loom. So hooking up F6 gaugues can't be done. Sorry Link to comment https://www.fordxr6turbo.com/forum/topic/36094-boost-gauge-plumbing/#findComment-554598 Share on other sites More sharing options...
gu4800 Member 156 Member For: 18y 22d Location: Brisbane Posted 13/07/07 03:55 AM Share Posted 13/07/07 03:55 AM Can anyone please offer some insight as to where the F6 boost gauge is plumbed into? I have read a few topics discussing plumbing the boost sender into the blow off valve however I have been advised that this may not produce the most accurate readings. Does anyone know of another location along the line where I could install the sender?Cheers,F6 is electric, and as such has a sender unit in the engine bay (I believe it is on the intercooler). That way, it only has an electrical signal running into the cabin (hence, via a harness).When plumbing to BOV as you describe (like most of us), you are running a mechanical gauge. Mechanical means you are actually tapping in a vacuum line and running it into your cabin. As to actually plumbing for accuracy, someone else is best suited to answering that question. The BOV plumbing is quick and easy.Hope this makes sense.CheersDan Link to comment https://www.fordxr6turbo.com/forum/topic/36094-boost-gauge-plumbing/#findComment-554617 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 5d Gender: Male Location: central coast Posted 13/07/07 04:04 AM Share Posted 13/07/07 04:04 AM should have added more to my reply I just had to laugh at a typical ford response " cant be done mate " dont try thinkin outside the factory walls you might get scared Link to comment https://www.fordxr6turbo.com/forum/topic/36094-boost-gauge-plumbing/#findComment-554623 Share on other sites More sharing options...
