T5 Still Alive!
ZelchXR6T
  • Replies 20
Posted Images
  • Member For: 20y 9m 16d
Give it to me and I bet it doesnot last 6 mins.
Tyres have a lot to do with it as it is the point of traction and load on the drivetrain.
Put on a decent set of tyres and the first burnout will be the last. Do not think you have a great gearbox, because the T5 Sucks and WILL DIE with your power level.
Sooner than later.
  • Member For: 19y 4m 28d
I had a suzuki swift with 72 front wheel kw and broke 6 gearboxs in 12 months because it would axle tramp and thump into gears, I turbo'd it and running 182 front wheel kw and it would spin every gear except 4th and 5th and I had this setup for 2 years and only broke 1 box, the wheelspin was taking the pressure off the driveline but not the clutch (21 later) :tonguepoke:
  • Member For: 17y 10m 15d
If they are so good you can have mine out of my car as long as you fit up my T56.
But it must happen this weekend as I will be doing it myself.
There you go a cheap super box for you.
it has only had close to 300 rwkw put through it for about 2 mths, I don't drop thee clutch anywhere but do wheel spin when boost hits 1st and 2nd with nice soft gear changes.
It is currently running Nizpro injectors, Nizpro Valve springs, X-Force system, capa flash custom tune and Excede clutch.
And when I say it's a super box I mean it sounds just like a v8 supercar box, screaming it's head off whinging.
Actually sounds like it is blown (Supercharged)
After all the searhing I have done I have found you can strengthen them by using dog gears but it still will cost like $4000 and will whine.
As for other options there is a lot of hassle and exspense in fitting the like's of say a TKO.
Your only option is to go T56 like me and alot of other people have done.
But you might as well wait till your box give's up as it is only worth scrap anyway.
And as eveyone on here has said once you do get traction and you have a clutch that holds your T5 will fail quickly as it will have to cope with all the load applied.
Have you heard a car on the dyno as the load is applied.
Listen to how hard the engine has to work and just think about how it is transferring that power.
The T5 is not engineered to handle the TORQUE your car will be making.
Good luck and I hope it holds up for you, I havn't been lucky as so many others.
  • Member For: 19y 3m 9d
I would be very interested in hearing a little more about the dog gear's you have discovered. Do you have a link or company name ? :)
The cheapest T56 transmission I have found is $4400 from Suburban Imports in Sydney
Cheers,
  • Member For: 19y 5m 7d
ppg do straight cut gear sets, but I couldn't find anything for the t5z when I looked. a member, xr6ism, has them in his t5. he doesn't post here any more but you may be able to find him on the autotech forum.
beware with straight cut gearsets though, they are a consumable, and the dogs wear out over a short period of time in the life of a gearbox. NOT recommended for the street, as they are hard to drive, and I dare say that you will go through axles if you have a button clutch.
op
you are on borrowed time mate, but I wish you the best of luck with it!
bvi
Jump on it before someone beats you to it.
If it's new it's a steel, if's it's used still not bad as they are hard to get.
I was lucky as I got mine off Mal Woods as a reco'd blueprinted box for a good price due to being a member of the XR6 & XR8 club of QLD.
Thanks Mal for looking after me.
Can't beleive Ford wanting $9000 for one.
Should have told them I didn't need the F6 engine that was attached.
You have just told everyone where this t56 is so if I where you I would hurry before you get beaten to it.
  • Member For: 18y 2m 9d
the car is running crow valve spring, high flow injectors, walbro fuel pump, hybrid intercooler, ss inductions growler kit etc. Clutch is extreme heavy duty and tyres are hard compound. That's why they don't stick so much all the time.
I'm not bragging, I'm just stating the fact that it's still working perfectly. And if it's the wheel spin, so be it.... I'm still enjoying it.
And finally.... If she blows, that's my problem, not anyone elses. So cheers to guys who are giving me good words. People saying ive jinxed myself don't relize that I don't 2 f*#ks if she blows. It's bound to happen... but just when is the question. Ive got an idea for those who want to be big shots.... put some money on it and start a betting forum to guess when it will blow :roflmbo:
  • Member For: 19y 4m 22d
Mate you have posted a topic on how good a T5 is , knowing that some people are going to disagree with you and then proceed to throw a hissy because they do. Crazy :blink:
Good luck with the T5, I hope it hold together for you. But I would start saving for that T56 conversion. :spoton:
