Hot Rod Not Tied Down To Dyno Properly.......
Maximus
  • Member For: 20y 1m 16d
The dope accelerated it too fast. It should be done gradually on the dyno
...makes absolutely no sense! - The whole object of putting anything on a accelerometer type dyno (like this one and most used commonly around the world) is to measure the accelleration of the dyno's rotating mass and covert that to kw's. You have to accelerate as fast as possible to measure the maximum kw's!!!! - otherwise don't bother.
  • Boostaholics anonymous
  • Member For: 18y 5m 29d
More than likley they only used small straps.
The 50mm wide straps are rated at 2t each, and are practicaly useless if they are frayed.
I wouldnt let my car on one of those dynos without 4 2 tonne straps holding it in place.
cause when they go, there is no warning.
  • 3 weeks later...
  • Member For: 19y 3m 9d
WTF?
Yeah, accelerate to WOT but do it gradually!
  • Member For: 18y 5m 4d
Because it's the same principal as getting on an excersise bike. Go to fast, you end up pushing the dyno ahead of the actual peak power (too big a push), giving you a false peak reading. Get on an excersise bike and peadle like crazy, then see how long it takes for the bike to cycle down back to your normal speed.
  • Member For: 19y 5m 28d
Coming from someone who has used a dyno, in this particular case, a Dyno Dynamics
You accelerate to WOT under "Ramp Hold" conditions. it doesnt matter if you do it slow or fast, the engine will only load upto say approx 2400rpm and stay there.. the dyno will hold the current wheel speed.
this is the point where you start to hear the xr6t turbos start to spool up.. because its almost like going WOT with the brake and handbrake on holding it at like 70km/h
after the RPM stablises, you select "ramp up", in which the dyno will allow the speed to increase (in which, the RPM increases)
once you reach RPM limit, or power drops of, or whatever, you then put it back to "ramp hold", and miliseconds afterwards, you get off the gas pedal.. (if you get off the pedal before you engage ramp hold, the graph draws back over itself)
danny
  • 1 month later...
  • Member For: 17y 7m 18d
:roflmbo:Ha ha ha. That was good. But it needed some sort of random fire to break out. Then it would have been really funny :innocent: Cool car though. Shame it hadda get scrathed up like that :spoton:
