ba_xr6_turbo Member 31 Member For: 21y 11m 13d Gender: Male Location: Geelong Posted 20/06/07 12:27 PM Share Posted 20/06/07 12:27 PM Hi PPLI ended up getting a second hand rip shifter off ebay and would like to know are they easy to install and whats the best way of doing so?CheersNick Link to comment https://www.fordxr6turbo.com/forum/topic/35964-rip-shifter-install/ Share on other sites More sharing options...
MUZ580 Member 448 Member For: 19y 3m 7d Gender: Male Location: Manly - Sydney Posted 20/06/07 10:46 PM Share Posted 20/06/07 10:46 PM First you take gear knob and lever out and the surrounding part of the console. Then get under the car and remove bolts that hold up the crossmember. Lower the back of the box down to create enough room to get to the bolts that hold the shifter to the box. Remove the old shift, making sure the plastic cup around the ball under the shift stays in the box, (it may come out with the old shift, take it of and place it in the selector mechanism in the box) clean the mounting surface for the new shift. Place a small bead of silicone or sealer around the mounting surface and bolt the new shift onto the box.Lift up the gearbox,re-fit crossmember bolts. Then attach lever,console surround, boot and knob. that's about the job done. If you can use a hoist it is easier but you can use car stands and a jack. Link to comment https://www.fordxr6turbo.com/forum/topic/35964-rip-shifter-install/#findComment-546554 Share on other sites More sharing options...
shnaped_second e-drifter Member 209 Member For: 18y 9m 2d Gender: Male Location: Gold Coast Posted 21/06/07 05:46 AM Share Posted 21/06/07 05:46 AM How much you pay for the shifter if you dont mind me asking? Link to comment https://www.fordxr6turbo.com/forum/topic/35964-rip-shifter-install/#findComment-546683 Share on other sites More sharing options...
ba_xr6_turbo Member 31 Member For: 21y 11m 13d Gender: Male Location: Geelong Posted 22/06/07 07:06 AM Author Share Posted 22/06/07 07:06 AM First you take gear knob and lever out and the surrounding part of the console. Then get under the car and remove bolts that hold up the crossmember. Lower the back of the box down to create enough room to get to the bolts that hold the shifter to the box. Remove the old shift, making sure the plastic cup around the ball under the shift stays in the box, (it may come out with the old shift, take it of and place it in the selector mechanism in the box) clean the mounting surface for the new shift. Place a small bead of silicone or sealer around the mounting surface and bolt the new shift onto the box.Lift up the gearbox,re-fit crossmember bolts. Then attach lever,console surround, boot and knob. that's about the job done. If you can use a hoist it is easier but you can use car stands and a jack.Thanks MateI will give it a try this weekendNick Link to comment https://www.fordxr6turbo.com/forum/topic/35964-rip-shifter-install/#findComment-547116 Share on other sites More sharing options...
ba_xr6_turbo Member 31 Member For: 21y 11m 13d Gender: Male Location: Geelong Posted 22/06/07 07:07 AM Author Share Posted 22/06/07 07:07 AM How much you pay for the shifter if you dont mind me asking?I got it for $300 Link to comment https://www.fordxr6turbo.com/forum/topic/35964-rip-shifter-install/#findComment-547117 Share on other sites More sharing options...
MUZ580 Member 448 Member For: 19y 3m 7d Gender: Male Location: Manly - Sydney Posted 29/06/07 03:43 AM Share Posted 29/06/07 03:43 AM How did you go putting the shifter in? Any problems or was it pretty easy? Link to comment https://www.fordxr6turbo.com/forum/topic/35964-rip-shifter-install/#findComment-549721 Share on other sites More sharing options...
ba_xr6_turbo Member 31 Member For: 21y 11m 13d Gender: Male Location: Geelong Posted 29/06/07 09:46 AM Author Share Posted 29/06/07 09:46 AM How did you go putting the shifter in? Any problems or was it pretty easy?Nah not yet, havnt had time been flat out at work:( might get Craig at ACE to do it or just wait till I get a new clutch. Link to comment https://www.fordxr6turbo.com/forum/topic/35964-rip-shifter-install/#findComment-549832 Share on other sites More sharing options...
