cqae Member 229 Member For: 21y 5m 27d Posted 19/06/07 05:37 AM Share Posted 19/06/07 05:37 AM I cant lock the ute. when I press the lock button on the remote, nothing happens. when I press the snib down manually, it pops back up after about 10 seconds, but not all the time. when I press the snib down then press lock on my remote, the indicators flash to say its already locked. unlock on the remote seems fine & I know the remotes are fine cos I have tried them on another car. its like someone has opened a door to pop the locks up, or they are stuck in open position so it wont listen to lock when remote is pressed. hope someone has seen this before & can help me Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/ Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 11d Gender: Male Location: stanthorpe wine capital of qld. Posted 19/06/07 05:39 AM Share Posted 19/06/07 05:39 AM It will be the main lock assy inside the door I have seen a few of these give problems.It wiill reqiure a new one.Ian Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-545900 Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 19y 21d Gender: Male Location: Bentleigh, Vic, Australia Posted 22/06/07 07:14 AM Share Posted 22/06/07 07:14 AM Actually my BF T has done something similar a while ago.At first I thought the battery in the remote was dead. But then when I finished work it was working fine.. Hasn't happened since... Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-547119 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 8d Gender: Male Location: Brisbane Posted 22/06/07 07:42 AM Share Posted 22/06/07 07:42 AM Have you checked to see that both your doors are actually locked buddy? Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-547134 Share on other sites More sharing options...
cqae Member 229 Member For: 21y 5m 27d Posted 28/06/07 08:13 AM Author Share Posted 28/06/07 08:13 AM sorry for taking so long, only just arounf to looking at this & forgot I made this post. I have tried disconecting both door actuators but it still does it-I can hear the clicking from the bcm. its as if the drivers door has been opened & the icc is opening the door for it. but the passengers door stays locked. basically, when I press the lock button on the icc or press the snib down, randomly the drivers door unlocks afyter varying times. am thinking bcm but gonna do some more tests tommorow. its actually a customers car & I am just getting into it tonight Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-549459 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 5d Gender: Male Location: central coast Posted 28/06/07 09:21 AM Share Posted 28/06/07 09:21 AM (edited) have you tried useing the key in the doorcheck fuses Edited 28/06/07 09:28 AM by our06t Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-549485 Share on other sites More sharing options...
cqae Member 229 Member For: 21y 5m 27d Posted 28/06/07 12:28 PM Author Share Posted 28/06/07 12:28 PM yeah checked all fuses. when you use the key in the door, it locks ok, but then most times will unlock by itself after about 1-5 mins randomly. if you lock with the key, then lock with the remote, the horn beeps to let you know the doors are already locked. Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-549592 Share on other sites More sharing options...
cqae Member 229 Member For: 21y 5m 27d Posted 02/07/07 06:47 AM Author Share Posted 02/07/07 06:47 AM thanks every one for their input. especially the person who sent me some info too, I forget who it was but sincerely thank you for your effort, if I find the email I will mention you personally.I should also mention, it wasnt actually my car, it was one I am working on, but same stuff, so couldnt be bothered with those details!but also got the fix-it was the bem. ended up fitting a new one, used my scanner to code the new bem & keys back into system & all is fine. I found if I disconnected the rf reciever, the fault disappeared as far as the locks popping back up were concerned but but the scan data told me the rf unit was recieving signals as it will show last revceieved button press in the data. also the fault still occurred with both doors disconnected(you could still hear the bem clicking & pwoer pulsing to wires at door actuator.anyways a few grey hairs later & problem solved, thanks to all those who took the time to try to help Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-550857 Share on other sites More sharing options...
swanee Member 48 Member For: 21y 4m 17d Gender: Male Location: Middle Earth (The Shire) Posted 09/07/07 03:24 AM Share Posted 09/07/07 03:24 AM simple. Its the drivers side door actuator. Link to comment https://www.fordxr6turbo.com/forum/topic/35917-central-locking-on-the-ute/#findComment-553272 Share on other sites More sharing options...
