  • Replies 61
  • Member For: 18y 1m
  6speedXR8 said:
I just got some parts in that will help you, I have got a Used front plate and bellhousing, an alloy CSC and steel flywheel and clutch from my own ute, it is perfect,that will come out after the weekend( I will be trying an upgrade) and I can get your transmission picked up and returned to you ready to fit for about $400 all up with insurance. We will rebuild it for $440 plus parts and I might even be able to get a sump if you need one. I should be able to save you thousands. Mal
I'm in Mal I'll do my best to call ya tomorrow. Thanks very, very much.
got some fresh piccies too...
  • Mal Wood Automotive
  • Member For: 22y 1m 13d
I will be at work for about 3 hours Friday and then down to QR to check out the racing and I will be there Sat and Sunday so I will not be back on here till Sunday night. The damage doesn't look too bad and will be easily fixed, I haven't got a crystal ball but I should be able to pick up your bits and return it rebuilt with my steel flywheel and clutch kit, new alloy csc, new braided lines, your T56 rebuilt and blueprinted for under $4000. regards Mal
  • 2 weeks later...
Well I have got the Steel flywheel and option 3 clutchout of the ute and it is in very good condition for a clutch that has been tried and tested!!! I have got the bellhousing and the front plate, an input shaft and bearing kit and now I am just waiting for your transmission. Mal
  • 3 weeks later...
Well we got your T56 stripped today and it will not be a problem to rebuild, all will be fine and quite reasonably priced. It will be ready to go back to you by Friday, I will give a report as soon as I can. Mal Wood
  • Member For: 22y 1m 1d
that's pretty scary if it happened on a stock T. Exactly what were you doing when it let go.
Do you think it was the clutch failure that took out the bellhousing or a bellhousing failure that took out the clutch.
  • Member For: 19y 1m 7d
you will love the new clutch.
iv done 2000 km on mine now and it is as smoothe as a babys bum and gripps tighter than a fishes ass..... :beerchug:
  Meggs_83 said:
PP took it all out, I think mal said sumn like clutch slipping and heating up then POP! was givin it a bootfull on a wet road
Did you notice a clutch smell at the time?
