How Much Vacuum Does Your Car Run?
cobrav8
  • Member For: 19y 9m 28d
Under normal load (not boost) - What pressure (vacuum) do your cars run at idle - or normal driving
I just installed a different gauge pod - and it seems that the reading may be higher - closer to 0 than it was before. I just wanted to know if I have a leak or anything. It still goes up as high under boost.
So if mine is running at about -2 what do you think is wrong - boosts fine - but vacuum is not there as normal.
Something to do with the right angle fitting that was installed to fit the new gauge pod?
Ill try again.. I had a kink in one of the lines when I installed mine and the guage read 0. check the set up again.
That is what it is looking like - I moved it a bit - and I am up to 9psi
Cheers
