BAturb Member 521 Member For: 19y 10m 3d Gender: Male Location: Adelaide Posted 17/06/07 04:42 AM Share Posted 17/06/07 04:42 AM how about a BF hard lid? would the bulge be enough to get your tuba under Link to comment Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 2m 27d Gender: Male Posted 17/06/07 05:00 AM Share Posted 17/06/07 05:00 AM yeh it adds a bit of extra height in the middle at the front of the tray.. enables my bike handle bars to fit.. and a big esky also Link to comment Share on other sites More sharing options...
F663 Member 70 Member For: 18y 2m 19d Location: Perth Posted 17/06/07 10:33 AM Share Posted 17/06/07 10:33 AM It would be a lot easier to mod the lid and add a buldge like you have a spare wheel in the back.Cheaper as its only glass not metal just my 10 cents worth Link to comment Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 17y 7m 26d Gender: Male Location: Dianella, West Oz Posted 18/06/07 05:39 AM Share Posted 18/06/07 05:39 AM (edited) When my old man bought the ute I now own he had some work equipment that he needs to fit under the hardlid which was only slightly bigger (hieght not length) than the hardlid would allow.We knew a dude that worked at ford so he went to clark rubber and bought some rubber lining and glued it around the edge of the hardlid to raise it. He drilled some new holes for the locks at the back (raised them), and used some longer bolts and added a strut type thing for the front (cabin end)... Its a BF hardlid and it raised it about 4 inches. When I bought it off me dad, it looked really high and I didnt like it, I barely ever have anythin in the tray so I ripped the rubber out, and basically took the struts out the front, went back to shorter bolts and screwed the locks back in the original holes and lowered it back to factory. Maybe you should look into this as opposed to what you were thinkin?? Edited 18/06/07 05:43 AM by Dirty32 Link to comment Share on other sites More sharing options...
Guest dico2020 Guests Posted 18/06/07 08:58 AM Share Posted 18/06/07 08:58 AM best bet would be to take the liner out, and see if there a place before or after the tank to sink the bell into to modify. Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 5m 27d Posted 18/06/07 10:13 AM Share Posted 18/06/07 10:13 AM Just to end the debate that there is no room underneath the tub liner Use your imagination and picture it without the tipping kit I have installed on it and you will see a flat chassis. This is what the tub sits on, there is metal under the tub liner and this sits directly on this part. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 4m 23d Gender: Male Location: Brisbane Posted 18/06/07 10:23 AM Share Posted 18/06/07 10:23 AM (edited) When there's a will there's a way!With a bit of modification you could gain a few inches here and there - definitely not worth the drama though. A tonneau cover would be the sensible option.PS: Not suggesting lowering the whole tray before your knickers get twisted again, just a section! Edited 18/06/07 10:24 AM by tab Link to comment Share on other sites More sharing options...
xr6me Member 26 Member For: 17y 3m 15d Gender: Male Location: Marrickville, Sydney Posted 23/06/07 02:07 AM Author Share Posted 23/06/07 02:07 AM Just to end the debate that there is no room underneath the tub liner Use your imagination and picture it without the tipping kit I have installed on it and you will see a flat chassis. This is what the tub sits on, there is metal under the tub liner and this sits directly on this part.so it seems there is room behind the wheel arch, where there is no chassis; so dropping just a section, the width of the wheel arch, directly behind it to the tailgate could be an option? does anyone have a contact to whom I could talk to about it? I've tried a couple of panel beaters but they dont do this sort of work. Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 9d Gender: Male Location: Mildura Posted 25/06/07 04:07 AM Share Posted 25/06/07 04:07 AM you COULD get under the ute, find a section of plastic tub that u CAN access and add a few inches depth, mark a square big enough to fit your oversized blow off valve in and get a plastic welder to make like a "lunchbox" section that hangs down.that's about all u can do mate... Link to comment Share on other sites More sharing options...
