Mr Turbo Next stage, to the Pub in 10 seconds Member 2,777 Member For: 20y 10m 19d Gender: Male Location: Berwick Victoria Posted 14/06/07 02:04 AM Share Posted 14/06/07 02:04 AM FORD GTX1SPECS:Year 2005 Make Ford Model GTX1 Engine Location Mid Drive Type Rear Wheel Weight 3485 lbs | 1580.8 kg Introduced At 2005 SEMA Engine Configuration V 90-degree Cylinders 8 Aspiration/Induction Supercharged Displacement 5.40 L | 329.5 cu in. | 5400.5 cc. Valves 32 valves. 4 valves per cylinder. Valvetrain DOHC Horsepower 550.00 BHP (404.8 KW) @ 6500.00 RPM Torque 500.00 Ft-Lbs (678 NM) @ 3750.00 RPM HP to Weight Ratio 6.3 LB / HP (Vehicles with similar ratio) HP / Liter 101.9 BHP / Liter Bore 3.55 in | 90.2 mm. Stroke 4.17 in | 105.9 mm. Compression Ratio 8.4:1 Fuel Type Gasoline - Petrol Fuel Feed Fuel Injected Electronic Returnless Sequential Fuel Injection Block Aluminum Head Aluminum Gears 6 Transmission Manual Ricardo Final Drive 3.36:1 Suspension Front Unequal length upper A-armslower L-arm aluminum control arms, coil springs, monotube aluminum dampers, 23-mm tubular anti-roll barRear Unequal length upper A-armslower L-arm aluminum control arms, coil springs, monotube aluminum dampers, 19-mm tubular anti-roll barTires Front P235/45ZR-18Wheels Front 18 x 9 in. 6-spoke cast alloy wheels Ok enough of the talk, you want to see how she goes? Here is a clip tested by Jeremy Carckson who we know is from Topgear is lucky enough to take this beast for some lasp around a desert track.cpy8xAKVadU Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/ Share on other sites More sharing options...
Billsta Member 355 Member For: 18y 11m 27d Location: Rolling on my 20's Posted 14/06/07 02:23 AM Share Posted 14/06/07 02:23 AM What an absolute Beast!Sounds Awesome, that's the only thing I'm missing from my phoon, replacing the bee nest with an angry bear! Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-543991 Share on other sites More sharing options...
DORKO Member 340 Member For: 18y 3m 21d Gender: Male Location: Perth Posted 14/06/07 02:24 AM Share Posted 14/06/07 02:24 AM WOW! Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-543993 Share on other sites More sharing options...
jason_85 Member 30 Member For: 18y 4m 8d Gender: Male Location: Mackay Posted 14/06/07 02:57 AM Share Posted 14/06/07 02:57 AM That is awesome! I like the mags in the last pic rather then the second Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-544007 Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 22y 10d Location: D SHIRE! Posted 14/06/07 03:06 AM Share Posted 14/06/07 03:06 AM Niceeeeeeeeeeeeee Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-544010 Share on other sites More sharing options...
Soul Reaver Member 136 Member For: 20y 10m 25d Gender: Male Location: Syd Posted 14/06/07 03:49 AM Share Posted 14/06/07 03:49 AM That is awesomeDo you think my soul is enough for that ? Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-544029 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 3m 4d Gender: Male Location: Canning Vale, W.A Posted 14/06/07 03:56 AM Share Posted 14/06/07 03:56 AM anyone wanna buy one of those for me ? Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-544031 Share on other sites More sharing options...
TUFXRT6 Silver Donating Members 687 Member For: 19y 3m 12d Gender: Male Location: Victoria Posted 14/06/07 05:40 AM Share Posted 14/06/07 05:40 AM (edited) I like it but......Whats with the cheap looking cd player!!!!Also they dont say anything about what size are the breaks?? The back ones look huge Edited 14/06/07 05:44 AM by TUFXRT6 Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-544057 Share on other sites More sharing options...
Mr Turbo Next stage, to the Pub in 10 seconds Member 2,777 Member For: 20y 10m 19d Gender: Male Location: Berwick Victoria Posted 14/06/07 05:49 AM Author Share Posted 14/06/07 05:49 AM Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-544060 Share on other sites More sharing options...
jasper361 Member 407 Member For: 20y 5m 16d Location: Brissy Norf siide Posted 14/06/07 06:04 AM Share Posted 14/06/07 06:04 AM I wonder if the starter button is any better that the poxy FPV one? Link to comment https://www.fordxr6turbo.com/forum/topic/35792-sex-on-wheels-and-its-a-ford/#findComment-544061 Share on other sites More sharing options...
