  • Member For: 19y 10m
Keep in mind that this isn't the first car to let go in such a way...
Goldie's car for one let go doing the exact same thing, slowing down for a roundabout.
The damage was already done from the last squirt
  • Replies 93
Posted Images
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 10m 9d
Was'nt the car pinging for awhile before it blew?
CYA JEFF :smilielol:
  • Member For: 21y 3m
16 psi is a lot of boost to run on standard T internals
good luck with the rebuild... time to wind her up!!!
Edited by jetute
  • Here since the start...
  • Member For: 22y 5d
It is? :spoton:
There's heaps of cars running around 15psi and I know of a couple running 18psi with no problems.
Boost isn't what kills them!
mine peaks at 15 if that's what your getting at.. others have pointed out that 15 maybe a little high but am glad to see that you disagree :flameman:
how many BA T's do you know that run 18 psi on an every day tune and who tuned them:blink: :unsure:
do you mean torque?? cause I will bring you a new update on a totally stock car shortly that just gave up the ghost.... as soon as the problem is diagnosed I will report.. am sure it couldnt be torque as car is totally stock.
If you dont mean torque what is it? and how much boost can we run if it aint got anything to do with it?
off to watch the game :biggrin:
What I said isn't totally accurate...
It's more the boost delivery (hard) that will cause failures.
I'm not going to speculate on the cause of this engine failure or any other for that matter, I'll leave that up to all the keyboard mechanics around here. The fact is there's heaps of reasons why an engine can fail!
The 18psi is an everyday tune and was done at the owners request and has been running happily for along time.
I've run a max of 15psi for almost 60,000kms with not a hint of trouble. :flameman:
exactly....
and im not saying the 16psi caused it... am just saying that its a fair bit to pump through the stock internals... considering these things are failing stock and that some cars sem to cop weaker bits then others.
if anyone thinks that 16psi or 18 psi is fine to run through stock internals on a T then that's up to them....
I too have run a max of 15 for the whole life of my car ... do I think the engine will last?/? who knows.... time will tell....
doesnt matter if you have 60K on the clock or 15K... if it lets go it lets go... it does not necessiraly mean its tune related.
  • Member For: 21y 10m 4d
I tend to agree.
I have a colleague at work with a NA MKII XR6. 30,000k's on the clock and the engine just lunched itself.
This guy is also a very conservative driver so abuse would not be an issue. Just goes to show that sometimes it just comes down to basic component failure regardless of mods or tune.
  • Member For: 17y 10m 16d
Can I ask how you normally drive ? do you drive the car hard, what mods do you have fitted, does it have an edit etc.. the reason I ask is it just doesn't gel that the engine can just "blow". I'm just trying to get my head around the amount of damage caused, when you went around the roundabout did you plant it ? or as you mention just cruised around and prior to the engine letting go had you given it an excessive fang? something that may have weakened the engine.
Sorry, bit verbose but I'm getting a T in a couple of weeks and just wanted to know.
Gary
