IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 5d Gender: Male Location: OZ Posted 06/06/07 10:12 AM Share Posted 06/06/07 10:12 AM Yeah its debateable how dangerous it is. Lots of people don't use bov's and they are not a std item on nizpro stage 2 kits. Same as letting your turbo "cool" down after running. The theory there is that when you turn the car off so does the oil pump (obviously) and there is no oil flow to the turbo... the turbo spins at 10+ engine speed so after shutdown the turbo is still spinning. Few people idle their car after running and I have not heard of that many turbo failures really. Having said that... revving the engine as you start it is even worse than not idling after driving. The reason being that the turbo spins before it gets oil and therefore no oil on bearings = not good!! All debatable issues, however the one I would be most concerned about imo would be revving on start up (but you would have to be a goose to do that!!). Keep in mind that I'm no mechanic and what I have just written is what has been passed onto me Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541288 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 16d Gender: Male Location: Canning Vale, W.A Posted 06/06/07 10:33 AM Author Share Posted 06/06/07 10:33 AM (edited) yeah 10psi wont help that!!! vacuum line wont/should not affect it. Even a K&N alone will get you a bit more gobble as the gobble is air leaving the filter itself.Yeah that's because of the bov design. the factory bosch valve is reverse vented and therefore vacuum operated only...so if you take it off and have a look inside you will notice the piston seals in a way that as soon as there is vacuum it's venting (either atmo or back into the intake, depending on set-up). Therefore you will hear noise (if atmo vented) even on low/moderate throttle. It also means it's suking in unfiltered air when cruising or at idle :(With this setup, would it be deemed ok?IT actually makes a really really cool noise the way it is now, and hopefully is safe.Looks the part for 10$ to gpMadjQdWo0 Edited 06/06/07 10:45 AM by Silhoutte6T Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541305 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 5m 4d Gender: Male Location: Perth, NOR Posted 06/06/07 03:37 PM Share Posted 06/06/07 03:37 PM Sounds good man. Mine sounds the same, only softer as its only pushing out 6psi :(I bought the same Monza filter as yours (in black though), but it sounded like it was releasing the air too easily and it was more of a slow whooooooooosh sound. Not very crisp at all. So I went back and bought their other type of filter (one that only lets air out the top of the filter) and fitted that. I liked that sound a bit better when running the stock psi.Heres pics of mine fitted. Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541402 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 5d Gender: Male Location: OZ Posted 06/06/07 04:14 PM Share Posted 06/06/07 04:14 PM cheap yet so effective Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541405 Share on other sites More sharing options...
trevs Member 781 Member For: 17y 11m 23d Gender: Male Location: balmain Posted 07/06/07 07:08 AM Share Posted 07/06/07 07:08 AM I tried this today now and my car feels like its missing or something at high revs any ideas why I also done the boost selniod thing with wd40 not sure which one caused the problem Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541586 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 16d Gender: Male Location: Canning Vale, W.A Posted 07/06/07 07:18 AM Author Share Posted 07/06/07 07:18 AM 8Rp1TkXRUnQ I reckon it sounds good, love the sound of my T with the muffler removed nowand trevs, just wait for IH8TOADS to come on, or just give him a pm, he'll know the problem Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541591 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 11m 9d Gender: Male Posted 07/06/07 07:23 AM Share Posted 07/06/07 07:23 AM (edited) Silho have you seen mine on you tube??that's with out the bov Edited 07/06/07 07:24 AM by YPURV4 Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541593 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 16d Gender: Male Location: Canning Vale, W.A Posted 07/06/07 07:26 AM Author Share Posted 07/06/07 07:26 AM yeah ive seen your vids mate, sounds mean as. At the moment though I just prefer keeping the BOV on, too many people tell me things about not having one is unhealthy etc Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541594 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 5d Gender: Male Location: OZ Posted 07/06/07 08:27 AM Share Posted 07/06/07 08:27 AM I tried this today now and my car feels like its missing or something at high revs any ideas why I also done the boost selniod thing with wd40 not sure which one caused the problemMmmm...... did you use wd40 or another spray? Evaporative type sprays such as wd40 are the way to go. Did you let the car sit before driving? If the bov mod is done correctly it should be unaffected. Hard to say, but throttle body probs I've heard of have been low rev issues to. As for missing, sounds strange? Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541639 Share on other sites More sharing options...
mercuryturbo Oh look.... a real car, with no hair dryer Donating Members 1,724 Member For: 18y 8m 3d Gender: Male Location: Fear and Loathing in Callala Bay Posted 07/06/07 11:24 AM Share Posted 07/06/07 11:24 AM 8Rp1TkXRUnQ I reckon it sounds good, love the sound of my T with the muffler removed nowand trevs, just wait for IH8TOADS to come on, or just give him a pm, he'll know the problem Must admit sounds pretty darn good Link to comment https://www.fordxr6turbo.com/forum/topic/35536-was-a-little-bored/page/2/#findComment-541715 Share on other sites More sharing options...
