  • Member For: 19y 8m 27d
I used to back off the accelerator all the way and then back on to match the revs as I engage the clutch...It seems I do not need to back the accelerator off all the way now.....I am not suggesting to do this under heavy acceleration....it just seems to help match the revs again as you change up.
How can this be harder on your gearbox..?
  • Replies 38
  • Member For: 18y 2m 6d
  bad inferno said:
I've owned the Manual 6 speed T for a couple of years and just worked out I can push the clutch in without taking my foot of the accelerator. Supose this is drive by wire stuff...The last manual I owned (ok 20 years ago with twin side draft webbers) could never of done that without rev'n the guts out of the thing.
Its a lot smoother now changing gears in normal driving....Must try it with our Honda euro
The only reason it seems you are able to leave the accelerator pedal in slightly is because they falcon accelerator pedal is slightly "doughey" the first section of pedal travel has little effect on rpm, this was a popular convern when the BA's first come out. When the falcon first arrived at our dealership, and us mechanics got to test drive them we also found this, Im not sure why this occurs, and must be part of the calibration in the drivetrain operation, because I have used the wds on countless cars and monitored the signals from the accelerator pedal on all of them with the them all showing to work smoothly and progressively on the graph. Just one of those things I supose but I actually prefer it now with the sprung button clutch cause I can blip the throttle on take off and not have the car rev so high. It works quite well
cheers
Mic
  • Member For: 18y 11m 22d
With my Ripshifter I can bang into 2nd and 3rd without the clutch, changing above 5000 works best.
Flat chaning with the cluch works only at 6000... my clutch doesnt grip too well if the revs fall under 4000
  • Member For: 21y 23d
RAP1D, did you use the hard mount to fit the gearstick to the ripshift or the factory rubber mount? I've got a ripshift to go in, and I'd be keen to know what ya think of it driving around the traps.
Edited by Spruce
Mine is a B&M ripshifter made for the US mustangs, so I had to mod it to fit.
But yeah, its a solid billet movment, not the crappy rubber/cast one. I shortened the factory stick a little and grinded/drilled it so it sit in the right spot.
Its the tightest shifter Ive come acrros and shifts very cleanly and fast
  RAP1D said:
You have to drop th gearbox a few inches to fit it too
Thanks for that mate :spoton:
Edited by Spruce
  • Member For: 19y 10m 19d
op,
I know what you mean mate.. I was mucking around with this on the weekend an got my 1st chirp into 3rd with the 17's.. its hard to do right as with that thread I resurrected if you get it a bit wrong there is a limiter thing. you defn shouldn't be fully lifting off the throtle when changing as the drive by wire is a little doughy, and I get major clunks..
flat shifting makes the limiter thingo kick in but do it right, and yer away :spoton:
  • Member For: 21y 10m 15d
  bad inferno said:
Its a BA MKII and tried it on my Euro which is also drive by wire however sure enough it just rev'd out not like the XR6T
I'm not saying floor the accelerator however in normal driving just push the clutch and change gears, the revs stay the same until you engage the next gear.
Has you car got an edit?
