Slave Cylinder @ Water Pump
xr6 typhoon
  • Good for nothing member
  • Member For: 20y 8m 3d
Over the last week I've noticed a couple of drops of oil on the floor of the garage every time I take the car out. At first I thought it was the air con because all oil levels were perfect but then I got under the car yesterday and worked out it must be the Slave cylinder. I read on here that they are useless and prone to I <3 Bananas up under high heat. Also while under the bonnet I notice the coolant levels are low and see that the water pump is leaking on to the block. Anyone got any ideas what this will cost me. The car is out of warranty to.
  • Member For: 21y 14d
If it is the slave cylinder it will be brake fluid, not oil and will smell different.
Mal Woods makes a heatproof one with braided lines that should fix the problem if it is the problem
  • Member For: 20y 11m 11d
I dont know about the prices of parts but the labour will cost the most. I beleave it would be around the $400 - $800 mark.
It could be leaking from the water pump itself or it could just be a gasket. They might have to clean and pressure test the system to see exactly were its coming from.
As for the slave, I have a t5 and im gussing its a gearbox out job to replace.
Bad luck mate, I hope it goes well.
its definately the slave and it is brake fluid dripping on the floor and its missing fluid from its little tank
Yea I knew I'd get raped by ford for labour. I can get a mate to do it at his work shop I just wanted it to get sorted before I go down the coast on the long weekend
