  • Replies 22
Posted Images
  • Member For: 20y 8m 8d
  SCRIBR said:
that's y I am leaving the stock suspension.. doesnt arouse suspison
Just dont lower it as low as michael has that's all, although its not that low :stirthepot:
You can buy little rubber blocks from auto pro that fit between the gaps in the springs. When you fit them and lower the car back down off the jack, they don't let the spring compress fully and make the car ride higher.
I used to have a fairmont ghia that spat sparks out the back over small bumps in the road when I drove it but I got numerous canaries off using them blocks. Just get them as high up the spring as you can so they cant easily be spotted and you'll be right :stirthepot:
  • Member For: 22y 4m 16d
I'm pretty sure that Ford use spring chocks while the cars are transported to the dealer. These are removed in pre-delivery so you might be able to get some lying around at your local Ford dealer.
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 1m 11d
You're not having much luck at the moment are you mate :stirthepot:
  • Member For: 17y 11m 25d
How much height do you need? You can try pumping your tyres up to some very high pressure. Not sure if this will work with lower profile tyres though.
