BFHOON Donating Members 1,932 Member For: 19y 1m 5d Gender: Male Location: nsw Posted 31/05/07 07:20 AM Share Posted 31/05/07 07:20 AM is anyone using the gizzmo boost controler,what do you think. Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/ Share on other sites More sharing options...
shnaped_second e-drifter Member 209 Member For: 18y 6m 25d Gender: Male Location: Gold Coast Posted 31/05/07 07:27 AM Share Posted 31/05/07 07:27 AM Used one in a mates car, there pretty average, have a bit of boost spike, the best ebc I have seen holding consistant boost levels was a profec b2, best boost controller cost $29 of ebay Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/#findComment-539127 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 5d Gender: Male Location: nsw Posted 31/05/07 08:12 AM Author Share Posted 31/05/07 08:12 AM heres a pic.the button mounts on the steering wheel and can do 6 programs or 3 scrambles in a percentage each press.either push to pass or 6 programs one per gear at the push of a button. Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/#findComment-539155 Share on other sites More sharing options...
2fardown Member 526 Member For: 19y 11m 18d Gender: Male Location: Brisbane Posted 31/05/07 09:56 AM Share Posted 31/05/07 09:56 AM Why would you need this? Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/#findComment-539204 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 5d Gender: Male Location: nsw Posted 31/05/07 10:55 PM Author Share Posted 31/05/07 10:55 PM im using this to stop the tyres from smoking up in first gear. reducing 60ft times. Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/#findComment-539304 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 9d Posted 01/06/07 12:34 AM Share Posted 01/06/07 12:34 AM BFHOON said: im using this to stop the tyres from smoking up in first gear. reducing 60ft times.I was going to say the factory PCM is a bloody good electronic boost controller, but after reading this I am interested, so you can adjust boost for a particular gear then? Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/#findComment-539330 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 5d Gender: Male Location: nsw Posted 01/06/07 01:15 AM Author Share Posted 01/06/07 01:15 AM yes. it has 6 programs accessable by pressing the wheelmounted toggle button.so you can have 8 psi on 1 10 psi on 2 and 15 0n 3 and press it after each change oryou can set up the scramble to give 5%more each press of the button, the percentage of boost up can be programmed and the time of boost up can be programed.so I can have say 30%duty and by pressing the toggle button it goes to 35% one more press goes to 40% and then 45% there are 3 levels of boost up and as I said the time of boost up can be set.so if u have 5 seconds boostup and u press it again before the 5 seconds is up u get level 2 for 5 seconds more. its a bit involved but I have it sorted now. Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/#findComment-539346 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 5d Gender: Male Location: nsw Posted 23/08/07 01:55 AM Author Share Posted 23/08/07 01:55 AM just an update on this.I have had this in the car for a few months now and im happy with how it works.I have the scramble setup have the boost levels set and the scramble works a treat.the only problem I have is that 69%= 9 psi and 70%= 12 psi 71%=13.7 and 72 goes too high for my tune. its like I need half settings to get more accurate adjustments.my conclusion is that it works good but a better quality product may perform better. ie eboost2... but for 400 bucks its ok. Link to comment https://www.fordxr6turbo.com/forum/topic/35439-anyone-using-a-gizzmo-ibc/#findComment-566925 Share on other sites More sharing options...
