  • Cruise Control
  • Member For: 19y 4m 18d
  groper said:
have you looked at www.snowperformance.net.
I think they are the manufacturer?
this looks like the one you need... http://www.snowperformance.net/product.php?pk=8
they say its for a centrifical blower or turbo, on a mustang.
they won't send to aust,you have to use there dealer
  • Into the laaaake
  • Member For: 17y 10m 9d
My sister lives in Atlanta, I can get it sent to her, then she ships it to me. But Summit Racing have it the cheapest. But they say they are nil stock...
But yeah, about 5 days to get it here.
For the guys that have it already, where are you mounting everything? Pump, reservoir???
Edited by hanra
  • 2 weeks later...
  • Member For: 17y 1m 30d
I had water methanol set up many years ago on my XF turbo. I worked great
and am considering installing to my bf. For those of you wishing to do on
cheap.. and I WILL NOT personally do it but it works..... A 6 to 8 psi pressure
switch and wire up to your washer bottle, then re direct windscreen squirters
to intake. use a mist spray from Mitre 10 garden dept.. This is how it was
set up on my XF (made cleaning windscreen costly) but can be done for
under $100.....
  • Member For: 18y 1m 10d
I have mine all fitted up
with a bit of luck I will have it tuned ready for the strip this week, I am going from 318rwkw and looking to make about 350rwkw, it will be interesting how much extra boost I need to make the power with the water/ethanol injection.
Yes that's water/ETHANOL as I am using 50/50 water and methylated spirits which is 95% ethanol and 5% methanol
  • Into the laaaake
Yeah but it got here quick and you didnt stuff around getting it fitted. Maybe I could of had it fitting to mine in time... Oh well.
ill give you some tips.
unless you are fitting the reservoir in the boot forget using the bottle they give you with the kit as it wont fit anywhere, if you want to fit it in the boot you need the solenoid upgrade kit. The pump will also have to be fitted near the reservoir so you will need probably an extra 6m of tubing.
I used my washer bottle as the reservoir you can still wash your windscreen with the 50/50 water metho mix as most washer fluid is 50% alcohol anyway.
The pump is very quiet, undetectable from in cabin.
The wiring is a piece of piss
You will need a 1/8 npt fitting with the smallest diameter hose barb on it that you can get as the boost signal hose is very small that runs to the little ecu that runs it.
