  • Member For: 21y 7m 20d
Does the monster tank have a baffle system inside it or a low point where the outlet is so that there is no "dry sucking"?
  • Member For: 15y 6m 13d
It's got a baffle moulded into it right behind the pickup. The pickup is at the lowest point.
AEM-30-3010-3.jpg?1403715038
Edited by Stazza_Brendan
  • 2 months later...
  • Member For: 12y 3m 16d
Reading with great interest, Apart from all the dick talk.....
I'm liking this water/meth injection idea for lower and much more consistent IAT....My car really suffers on a warm day. The difference between 15° night and 25° day is massive.
Something similar to this kit would fit nicely where the stock air box use to be......
Everything is right there......manifold pressure is right there on the bov vac line, nozzle can be mounted into the pw pipe before the throttle body with the tank and pump mounted right bellow it on a bracket.....
  • Member For: 10y 11m 22d
^^^ Same,same.
I re-read this thread today and I think that's the way I will eventually go with my stock setup.
  • Member For: 17y 9m 1d
  On 08/07/2014 at 4:42 PM, GUN-808 said:
I take that back LOL
tonights readings have put the AquaMist to a clear leader.. its the business !!
although its added another $100+ on the bill :( haha
http://www.aquamist-direct.com/806-063-hfs3-v3-pwm-valve-system/
and heres a cool chart with the players and their cost vs features etc
Same here, was thinking snow stage 3 was attractive till I saw these mob. Problem is that it looks much more complicated to install and when it isn't just controlled by boost, then it gets scary!
  • Moar Powar Babeh
  • Member For: 19y 7m 1d
You guys spending $$$$'s on these kits are clowns, all I did was pop the head off, notch the headgasket at each water port seal so it channels past the fire ring and then I just run a boost hose to the header tank.
I only need to top the water up three or four times a day so IMHO it's a killer setup.
  • Like 6
