  • Member For: 11y 6m 9d
^^^ that's my plan, looks like the highest place to put it.
But I was going to cut it and put in a small metal section to mount the nozzles. Dont like the idea of mounting them in that poxy plastic.
Edited by barnz
  • 2 weeks later...
  • Member For: 21y 8m 26d
I think snow sell a screw in bung for silicon piping which could be used to fit into the plastic if you can get a flat-ish section! A silicon washer each side and nip it up tight should be enough...
  • Member For: 15y 7m 18d
I'm looking to get a 1/8npt bung made and weld it into the alloy section before my throttle body. I've got a plazmaman plenum. Should place it at least 4 inches before the throttle body this way.
Going to mount my tank this weekend. Bought some 3mm alloy sheet and 3mm right angle alloy length.
With the placement in the tray I'll lose very little tray space as it's in the awkward area above the fuel filler section so I'm not losing much usable floor space. Mounting the tank up high means I can mount the pump underneath the tank.
Going to a mates engineering shop later to cut the pieces to size. Gotta look better then me butchering it with a hacksaw in the shed. Pics for placement. Final product will shield the tank.
Probably won't make much sense till it's finished.
Edited by Stazza_Brendan
Makes perfect sense mate, I had a similar idea in regards to the nozzle mounting.
That's a nice big tank, im sure you are already aware of the precautions required when mounting it that high(solenoid required).
Yeah I got a solenoid for it. Will mount it near the nozzle in engine bay somewhere. The AEM controller has an output for solenoid.
Pieces cut and bent into shape. Mate also welded brackets on so I can use less bolts to join it all together. Just have to drill some bolt holes and mount pump.
  • Like 2
All but done. Going to change the zinc bolts for stainless and use nyloc nuts. First I'll pull it apart (only 2 pieces to the mount now) and clean/polish it up. Also clean out the tray as it's filthy.
Outlet on tank points down through hole in mount down to the pump.
  • Like 2
