  • Member For: 21y 8m 17d
Got my mate to reply, he has the no.6 fitted which is the biggest they come with. Spraying starts at 10psi and always runs a 50/50 mix. Fg turbo with standard gt3540, original stage 2 pw IC kit with turbo side intake, 60lb inj, single 3.5in xforce with cat still in place! About 400rwkw so conservative numbers. Dave the owner of CPV has tuned a few cars with the kits over the years so has no problems with them.
  • Member For: 21y 9m 15d
There is no issue with fitting the biggest nozzle other than having to pull a fair amount of fuel from the factory injection. To balance my tune and maintain the desired AFR to make good power, a total of 14% would had to have been trimmed from the factory injection. This isn't an issue but can be a real problem if the water/meth pump fails. This will more than likely result in a blown engine. I wasn't willing to take such a big risk.
Benny.
Below photo is from my mates car. I asked him how far the nozzle was from the TB and got this photo! Haha
Doesn't your stage 3 setup have some funky getup that can release boost, timing or whatever in the event of the water/meth pump failing?
Edited by bjc
The Stage 3 kit doesn't have that functionality but I think an additional controller can be purchased as a fail safe. Not sure how it would integrate to our cars though. The difference of the Stage 3 kit is it has an electronic controller and the ability to trigger from boost or injector pulse width or both depending on how you program it.
Benny.
Ok, I thought it might have come with the failsafe controller! My stage 1 kit only has a manually adjustable boost actuator thingy...
I'm pretty sure my mates activates at 10psi.
  • Member For: 18y 2m 15d
If you are using the water/meth as a substitue to pump fuel, a smaller jet will be fine. When I was still running pump 98 and a stage 2 pw cooler, with a 375ml jet, intake temps were down in the low 20s degrees celsius. you wont need to pull fuel out. Ive use a 625 or 675ml jet on 98 and the richer afr didn't hurt power at all.
If you aren't going to use the water meth as a power added and just a safety (as I was originally as I was learning to tune and didnt want to grenade the stock engine) tune it without the water meth. Hook the meth up and enjoy.
  • MattyP
  • Cruise Control
  • Member For: 13y 17d
Heaps of good Info there guys
So your saying on 98 and is activated at say 6psi I won't need to adjust the tune on straight water? And the afr will be richer?
My car using the biggest nozzle dyno'd with an AFR of 10.5:1, which was way too rich. This AFR resulted in a loss of power right up until the run was aborted at around 4500rpm.
Benny.
use water and meth, and a 175ml jet. You wont need to adjust the tune unless it is stupid rich to start.
Benny.
So your base afr (without water/meth) was about 11.5:1 then and your using the water/meth for safety measures not for power gains?
I have been reading and a more appropriate name for it is "Chemical Intercooling" as the gains are made by the cooler intake temps.
Watched a few youtube videos on quenching also with turbo diesels (as I think a gas engine would prob die...) and it's puffing billy bigtime! Haha
