Dyno-mite Ute 10.22@136.49 Mph (factory T/b Manifold)
FSIX
  • Member For: 20y 9m
I would like to know that as well, it would be handy info, I don't know how much they were running,
but it would be good if he could do a run with out, one pass just to see.
David
  • Replies 38
  • Member For: 19y 7m 25d
I asked dion and he was running about 378rwkw (it ran 10.9@124 with 360rwkw). and a 50hp NOS kit, it's gained at least 10mph just with 50hp shot :w00t2: . I guess it would be about 80rwkw gain with NOS.
  • Member For: 18y 7m 16d
I asked dion and he was running about 378rwkw (it ran 10.9@124 with 360rwkw). and a 50hp NOS kit, it's gained at least 10mph just with 50hp shot :banghead: . I guess it would be about 80rwkw gain with NOS.
For roughly around $3k+, up to 80 rwkw is bank for your f*cking buck!
  • Member For: 20y 6m 23d
So is it a dry or wet shot system? Does it matter which way you go (I'm guessing with dry shot you need another computer map, therefore a xede/unichip, do you need one with the wet shot?). Where is the nozzle located (it has to be before the throttle right, made the cool side of the ic is a good place)?
I'd love to have nos run through a fpv starter button on the dash, it's like that's what it was made for imo. Found a few adjustable kits from 35 - 75 hp for around $1k here http://www.modyourcar.com.au/?cPath=11_80_128. If I do go mad and rebuild the bottom end, I think I'd have to add the nos.
The Nos system is a wet manifold single fogger system which sells for $800-$900 dollars, very cheap power if you have a strong enough bottom end to take it
You would never bother with a dry system, have never heard of using them with turbo's only non turbo low horsepower applications
The single fogger sytem it uses the nozzles after the throttle body, you use it under W.O.P only.
Edited by phase3ute
