Jimbob Member 148 Member For: 18y 1m 11d Gender: Male Location: Melbourne Posted 27/05/07 02:17 AM Share Posted 27/05/07 02:17 AM Topic pretty much says at all where to I find the factory fuel sensor and what do I connect to once I find it?I did a search of the forums I could not find the info I wanted so sorry if if has been covered beforeCheersJim. Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/ Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 2m 9d Posted 27/05/07 02:24 AM Share Posted 27/05/07 02:24 AM Ok your not looking for a fuel sensor wire, your actually looking for the wire the PCM reads the air fuel ratios from, which runs of the EGO (o2 sensor). Do a search for that and you might have some more luck. I recall it was a white wire from memory, I could be wrong though Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-537576 Share on other sites More sharing options...
Jimbob Member 148 Member For: 18y 1m 11d Gender: Male Location: Melbourne Posted 27/05/07 02:34 AM Author Share Posted 27/05/07 02:34 AM (edited) Fat-Tony said: Ok your not looking for a fuel sensor wire, your actually looking for the wire the PCM reads the air fuel ratios from, which runs of the EGO (o2 sensor). Do a search for that and you might have some more luck. I recall it was a white wire from memory, I could be wrong though Ok yeah that's what I ment to say but I have no idea where I would even find that wire can someone pin point it for me EDIT: ok so its someplace around the inlet manifold is that right? Edited 27/05/07 02:45 AM by Jimbob Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-537580 Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 2m 21d Gender: Male Location: Peninsula Posted 27/05/07 03:03 AM Share Posted 27/05/07 03:03 AM Look for the black wire on the sensor and either splice into that one or the grey wire on the other side of the black wire....if that makes sense to you Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-537586 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 2m 9d Posted 27/05/07 03:20 AM Share Posted 27/05/07 03:20 AM Just had a look at the wiring diagrams, Its a 4 wire heated sensor, you will find that it should have a black wire to ground the heating element, a P that goes into the heating element, and GR* which is the wire that goes into the ecu you want to splice. From the post above I assume that GR* means grey and a grey wire with a red stripe if I am not mistaken Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-537589 Share on other sites More sharing options...
kissy Member 132 Member For: 18y 2m 15d Gender: Male Location: S.E. Melbourne Posted 04/06/07 08:43 AM Share Posted 04/06/07 08:43 AM Just thinking but wont a AFR gauge be pretty much useless because the factor oxy sensor it's only a narrow band, and to get the proper use from a AFR gauge you need a wide band Oxy sensor welded into your exhaust... Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-540517 Share on other sites More sharing options...
Jimbob Member 148 Member For: 18y 1m 11d Gender: Male Location: Melbourne Posted 04/06/07 08:47 AM Author Share Posted 04/06/07 08:47 AM Yeh I'm starting to think that now after getting it oh well its a funky disco light untill I replace it with something alittle more functional Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-540522 Share on other sites More sharing options...
kissy Member 132 Member For: 18y 2m 15d Gender: Male Location: S.E. Melbourne Posted 04/06/07 11:22 AM Share Posted 04/06/07 11:22 AM Jimbob said: Yeh I'm starting to think that now after getting it oh well its a funky disco light untill I replace it with something alittle more functional Or you could buy a wide band sensor, but that'l' set you baock at least $350. With the stock narrow band sensor it's pretty much either ON or OFF at the switching point (correct me if I'm wrong) of an AFR of about 14.7 Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-540608 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 2m 9d Posted 04/06/07 12:06 PM Share Posted 04/06/07 12:06 PM kissy said: Or you could buy a wide band sensor, but that'l' set you baock at least $350. With the stock narrow band sensor it's pretty much either ON or OFF at the switching point (correct me if I'm wrong) of an AFR of about 14.7Not quite. Wide band sensors have come down in price of late. Now the AFR gauge with a narrow band sensor will be most accurate when around the 14.64 range (1 lambda) but as it moves from this AFR point its accuracy becomes diminished. None the less it will still retain some accuracy as to tell you if the car is running lean or rich but the further you vary from 1 lambda the less accurate it will be. Still would come in handy if you saw lean on the gauge when you were a WOT. Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-540649 Share on other sites More sharing options...
Jimbob Member 148 Member For: 18y 1m 11d Gender: Male Location: Melbourne Posted 04/06/07 12:29 PM Author Share Posted 04/06/07 12:29 PM I still need to get off my ass and install all 3 anyway I have everything I need I jsut can't seem to find the time and still I have no idea on the afr Link to comment https://www.fordxr6turbo.com/forum/topic/35351-gauges/#findComment-540661 Share on other sites More sharing options...
